Just a question for all those 12v gurus out there can I run a parallel battery set up with a 110amp gel and a 110amp lithium battery setup, I’m running full victron kit ie: mppt, Orion dc/dc and IP22. Or is this a definite no no
tbf the op's original question was can he run a lifePo4 and an Agm side by side.The way you have taken the discussion might not be relevant to my set up but is it relevant to the OPs set up? I don’t know whether Poutie57 has the type of BMS that would allow him to control charging as you would suggest. Perhaps my set up is just as relevant as yours.
Similar here but my engine battery is not topped up by solar so I use a battery Master between the Lithium & the engine battery.yeah I,m running 150ah lithium with 95ah agm in parallel with 50a b2b connected to engine battery.
Yes and bigtwin has pointed out that you can if you have a configurable BMS. I have pointed out the potential risks of such an arrangement if, like me, you do not have a configurable BMS. I was told the discussion wasn’t applicable to my set up but we now know the OP doesn’t have a configurable BMS either. Why is my fairly typical arrangement not applicable to the OPs original question?tbf the op's original question was can he run a lifePo4 and an Agm side by side.
My BMS doesn’t play any part in controlling charging, it is there to protect the battery from extremes and to do cell balancing if needed. The B2B/mains charger profiles control the charging and will shut back to a maintenance voltage as soon as the Li profile terminal voltage is reached.
As I explained above, your system isn’t capable of being configured in the hybrid arrangement that I’ve been discussing.In which case this discussion isn’t really applicable to your setup.
How can it be relevant if you are not mixing battery types?Perhaps my set up is just as relevant as yours.
As I said earlier, the OP has to decide whether his system is suitable for adopting this arrangement; he has now clarified that it is not.The OP will have to decide whether or not his system is compatible with the requirements that I’ve outlined. You have, and yours isn’t.
That how discussions work; information is given/teased out and conclusions are drawn.I was told the discussion wasn’t applicable to my set up but we now know the OP doesn’t have a configurable BMS either
Because, as I understand it, you are not configured for, and have no plans to, adopt a mixed battery setup.Why is my fairly typical arrangement not applicable to the OPs original question?
I discounted a mixed battery set up for the reasons I gave at #16. I removed a perfectly good nearly new Gel battery when I transferred my Lipo to my current motorhome and I still have it stored fully charged and available.Because, as I understand it, you are not configured for, and have no plans to, adopt a mixed battery setup.
sorry, I didnt realise you were considering going hybrid.Yes and bigtwin has pointed out that you can if you have a configurable BMS. I have pointed out the potential risks of such an arrangement if, like me, you do not have a configurable BMS. I was told the discussion wasn’t applicable to my set up but we now know the OP doesn’t have a configurable BMS either. Why is my fairly typical arrangement not applicable to the OPs original question?
I dropped the idea a few years back and have since found the Lipo on it’s own works well enough for me. For a while they sat next to each other in the battery box with one or the other connected but not in parallel.sorry, I didnt realise you were considering going hybrid.
No because as far as I know most Lipo batteries do not have a BMS that can be configured in this way. Perhaps some do.And were your concerns not addressed by my response in #18?
Ian
While not wishing to curtail your involvement in any way, I'm not understanding your issue with this discussion then?I dropped the idea a few years back and have since found the Lipo on it’s own works well enough for me. For a while they sat next to each other in the battery box with one or the other connected but not in parallel.
I am simply trying to point out that in some set ups the AGM/Gel battery may not get properly charged and could deteriorate. This seems relevant to the OP’s original question.While not wishing to curtail your involvement in any way, I'm not understanding your issue with this discussion then?
the point is that the setting are left as original and not changed to a lithium setting. probably easier on the leads than normal (these days) inverter use .I am simply trying to point out that in some set ups the AGM/Gel battery may not get properly charged and could deteriorate. This seems relevant to the OP’s original question.
You addressed it by sayingI addressed that aspect in post #18.
Ian
which is only applicable to those with a configurable BMS not for those without.In a hybrid arrangement, you need a configurable BMS with separate ‘control’ and ‘hardware protection’
You need to make up you mind whether your issue is with the correct charging of the lead (which is the initial concern that you raised, and repeated in your reply to jongood in post #41, and which my post #18 addressed) or the fact that the hybrid arrangement needs a configurable BMS which you do not have.You addressed it by saying
Nothing to be gained from conflict.You need to make up you mind whether your issue is with the correct charging of the lead (which is the initial concern that you raised, and repeated in your reply to jongood in post #41, and which my post #18 addressed) or the fact that the hybrid arrangement needs a configurable BMS which you do not have.
This is my last response to you as you appear to be seeking conflict.
Ian
Thanks again for all the info, it’s interesting to read the differing opinions on a subject. I think I’m going to try and parallel them with the B2b set for gel and wired into the gel and the mppt wired into the lithium with the outgoing live taken from the lithium to the Han panel
Thank youIf you’re wiring the batteries in parallel it doesn’t matter where you connect the two charge sources; they are not electrically independent.
If you are unable to configure the BMS with hybrid specific settings, I’d take further advice about what you have outlined that you intend to do as you will not be adopting a setup that is well proven.
Ian
The B2B normally charges the hab from its connection with the Engine battery. As soon as engine stops the system normally disconnects the B2B from the Engine battery. That is why your solar doesn't normally charge the Engine battery and why many Funsters insert a battery master between the 2 batteries, allowing the hab battery to top up the engine battery, whilst also preventing back feed from the engine battery to the hab battery, just in case of too much TV watching, lighting, compressor fridge or heating fan running.tbf the op's original question was can he run a lifePo4 and an Agm side by side.
you don't need a B2B with hybrid, unless you have a "silly smart" alternator.The B2B normally charges the hab from its connection with the Engine battery. As soon as engine stops the system normally disconnects the B2B from the Engine battery. That is why your solar doesn't normally charge the Engine battery and why many Funsters insert a battery master between the 2 batteries, allowing the hab battery to top up the engine battery, whilst also preventing back feed from the engine battery to the hab battery, just in case of too much TV watching, lighting, compressor fridge or heating fan running.
I’ve got the CBE equivalent of a battery master and have installed a n/c relay (thanks to Pausim for his help on that) so all that side of things are taken care of. The rest of the equipment is all victron so I can set it all up with the right charging profilesThe B2B normally charges the hab from its connection with the Engine battery. As soon as engine stops the system normally disconnects the B2B from the Engine battery. That is why your solar doesn't normally charge the Engine battery and why many Funsters insert a battery master between the 2 batteries, allowing the hab battery to top up the engine battery, whilst also preventing back feed from the engine battery to the hab battery, just in case of too much TV watching, lighting, compressor fridge or heating fan running.
I have fitted the CBE unit to my VW T6.1 and it works really well, could you tell me what a n/c relay does.I’ve got the CBE equivalent of a battery master and have installed a n/c relay (thanks to Pausim for his help on that) so all that side of things are taken care of. The rest of the equipment is all victron so I can set it all up with the right charging profiles
It basically cuts off the split charge stopping the B2b from looping back to the cab battery when the B2b kicks in whilst drivingI have fitted the CBE unit to my VW T6.1 and it works really well, could you tell me what a n/c relay does.
John.
I found that setting the Victron MPPT to AGM resulted in very high full charge voltages of up to 14.7v which is not good for longevity of the battery... I changed it to LiPo and it now stays below 13.7.I’ve got the CBE equivalent of a battery master and have installed a n/c relay (thanks to Pausim for his help on that) so all that side of things are taken care of. The rest of the equipment is all victron so I can set it all up with the right charging profiles
