Just a question for all those 12v gurus out there can I run a parallel battery set up with a 110amp gel and a 110amp lithium battery setup, I’m running full victron kit ie: mppt, Orion dc/dc and IP22. Or is this a definite no no
Well you can as that is what the Hymer hybrid system does, others including jongood are also doing it but I am not sure of the pros and cons.Just a question for all those 12v gurus out there can I run a parallel battery set up with a 110amp gel and a 110amp lithium battery setup, I’m running full victron kit ie: mppt, Orion dc/dc and IP22. Or is this a definite no no
I would imagine that if you set the mppt charger to the max of the gel battery then it should be OK and wont overcharge it ,but the lithium would be undercharged.
the lithium will greedily soak up most of the charge the from the alternator via b2b and when charging stops the lithium will continue to charge the agm until full... well that's how I see it, seems to work without issue![]()
Can I ask what settings do you use on your B2b and mppt…. Gel or lithiumyeah I,m running 150ah lithium with 95ah agm in parallel with 50a b2b connected to engine battery.
Won't you just end up with a system that's running from lithium pretty much all the time until it's pretty much dead?
Or... you're carrying 25kg that you're unlikely to ever use. That's leeching power all the time to keep topped off. And when you do use it, it might have life expired. A bad backup is worse than not having one at all.Yes, sort of, the LiFePo4 will carry most of the load but if it needs a little help from the leads they’ll provide the backup.
These characteristics are absolutely ideal in terms of capitalising on the benefits of the LiFePo4 and looking after the leads. The LiFePo4 provides the heavy lifting and recharge quicker than the leads (that require long charge times for the last 20% SoC) and, in the event that the leads require a charge, the LiFePo4s will keep them nice topped up. In terms of your comment ‘until it’s pretty much dead, remember that LiFePo4s will provide you with 1,000s of cycles unlike the few 100s provided by leads. It really is a marriage made in heaven. Pure lead systems will die well before either the leads or the LiFePo4s will in this hybrid arrangement.
Ian
thats one of the points if you're not using a B2B, the lifePo4 will take almost all the charge from the alternator until the BMS shuts off effectively isolating itself while the lead/gel/agm acts as a buffer and more likely kicks the alternator into absorption.I need a bit more convincing. AGM need a higher voltage charge to keep them in good condition and GEL need a long absorption phase to look after them. The LiFePO4 will provide a maintenance level charge voltage only but not lead acid charging voltages. The Li will suck up the main charge keeping the voltage down around the 13.5V level, at the end of the charge the voltage will rise rapidly to say 14.6V but as soon as it reaches the terminal voltage of the Li profile it will shut back to a maintenance level of about 13.5V. When do the lead acid parts of the hybrid get the absorption phase they need?
My BMS doesn’t play any part in controlling charging, it is there to protect the battery from extremes and to do cell balancing if needed. The B2B/mains charger profiles control the charging and will shut back to a maintenance voltage as soon as the Li profile terminal voltage is reached.
What about if you have 2 B2b’s charging the individual batteries, or is that then complicating things more
How many off the shelf LiFePO4 leisure batteries have a BMS that allows you to control the charging function? When I purchased my battery 5 years ago I don’t recall any of them having a BMS that allowed this. I know there are one or two like Fogstar that now have bluetooth connections.In which case this discussion isn’t really applicable to your setup.
For some reason, folks always major on the protection aspect provided by the Battery MANAGEMENT System. As you’ve recognised with your comment re balancing, it also provides a control/management function.
On the batteries on my boat, prior to leaving the boat for any period of time, I regularly used to isolate (via the BMS) both the charge input to the batteries and the discharge outputs leaving the lead acids to supply any (small) loads and to be charged by the solar.
Ian
No I don’t I was just wondering because the charging profiles are different but I do remember when I brought my lithium people said you could set your main ehu charger to gel profile.
The way you have taken the discussion might not be relevant to my set up but is it relevant to the OPs set up? I don’t know whether Poutie57 has the type of BMS that would allow him to control charging as you would suggest. Perhaps my set up is just as relevant as yours.As I said in my previous response, the discussion isn’t really pertinent to your setup.
Yep your right haven’t got the bms which I can play about not even Bluetooth,The way you have taken the discussion might not be relevant to my set up but is it relevant to the OPs set up? I don’t know whether Poutie57 has the type of BMS that would allow him to control charging as you would suggest. Perhaps my set up is just as relevant as yours.
