Can I replace the gas electronic crash sensor changeover valve for a manual one (3 Viewers)
Al n Val
2,624
6,787
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
as above
i've had 2 replaced under warranty and another one being changed this coming thursday morning, that will be the last one as i'm sick of them. No crashes, no bumps or thumps along the journey, they just decide to stop working once I get to where i'm going as in Pickering last thursday :mad:
Leaving me with no fridge, hot water or cooking on gas
So is it just a matter of removing the valve whats on atm and changing for a manual reset one and if so any ifs and buts and recommendations
cheers
Al
PS. can Basildog advise, and if poss are you attending Drax this weekend
Jan 11, 2022
1,019
1,118
Pilote P732 2011
3rd Time around, since 2000
as above
cheers
Al
Al n Val you wasn’t far from Basildog when you was at Pickering.
Don’t see why it cannot be swapped out, you never really travel with gas on anyways
Jan 11, 2022
1,019
1,118
Pilote P732 2011
i've just looked and your right, tbh i've just spoken to Charlie and he's advised me so looks like i'll be paying him a call
Sounds like a nice fella btw (y)
Don’t mention thread tape though.
Are going manual valve or manual with crash?
Dec 31, 2010
2,826
6,410
Sunny South Shields
Frankia Platin i7900
Since 2010
as above
cheers
Al
You just need one of these Al
Al n Val
Al n Val
2,624
6,787
since 2018
hi Dave
thats whats on it now but as you know there is the electronic solenoid below it operated by the crash sensor so i'd be exactly the same as i am mate wouldn't I if i didn't have the solenoid bit removed
Dec 31, 2010
2,826
6,410
Sunny South Shields
Since 2010
hi Dave
It's totally different, the solenoid valve is between the changeover and the 10mm compression fitting this cuts the valve out
Jan 11, 2022
1,019
1,118
Pilote P732 2011
Al, is this yours the black circle?
Jul 6, 2009
2,062
2,607
We cured urs by putting an inline LPG filter between the supply and the regulator, might be an idea to turn the bottle towards the regulator to take sharp curve out of the flexible pipe.
Al n Val
Al n Val
2,624
6,787
since 2018
Basildog
So an update
called in at Charlies this morning at Autogas 2000
All the electronic junk was disconnected and removed
new 2 way gas regulator with manual crash reset fitted, all gas tested for leaks and pressure test and voila
We have gas again :clap2:
thanks Charlie for getting me in at very short notice, recommend these guys 100%
Al (y)(y)(y)
Dec 2, 2019
4,633
10,330
South Lincolnshire
Rapido 7065+
Broken most bits now
Just as an aside, ours kept tripping to red led/crash sensor off when the voltage around the van went up to about 15v with a dubious solar controller. An improved MPPT solar controller has sorted the problem
Al n Val
Al n Val
2,624
6,787
since 2018
i'm all Victron gear so hopefully not that
it was explained to me by Charlie and his mate that the elec one "HAS" to be mounted completely flat or it will just trip out anytime, mine had been mounted on double sided tape on a near 45dg cab floor so possibly why i've had 3 already under warranty and gonna get a 4th one thursday, hopefully thats all behind me now and another manufacturing blunder sorted ;) (y)
