Not a good idea Duane, you have stretched your good luck to the limit with no belt change at 118,000 mlsWhats a cam belt?
I've got an 11 year old Peugeot Partner on all its original belts and ancillaries at 118,000 miles
I'll keep going until I hear the snap!
when you hear the "snap" that could very well be terminal for your engine, and it will be too late for just a belt replacement
bent valves, broken valve guides ,cracked cylinder head, damaged piston tops are all possibilities
