Lenny HB
- Oct 18, 2007
- 60,765
- 193,012
- Carthago Compactline
Yes no over pressure protection in those regulators and probably the incorrect pressure too .I think he means the ones on your bottles are only single-stage and don't have a pressure relief valve.
I know with most German vans inc., Hymer etc., the standard fit is a bottle top regulator, it does have a pressure relief valve, the bulk head regulator is an option . Any comments Basildog
Yes the regulator you have mounted on the wall is a leisure vehicle specific item , 2 stage 30 mbar incorporating an over pressure protection device built in .I wouldn't know where to buy any other than the ones sold by every caravan and camper supplier.
Is the factory fitted regulator supplied different?
Yes that’s as it should beIs my new van set up any better?
Most lpg fork lift trucks have the bottle fitted horizontally , Can't see how it could be dangerous with an empty one.BUSBY.It’s the empty U.K. bottle I’ll have the problem with. My gas locker holds 2x 13kg so I can replace one with a foreign bottle but don’t want to ditch the old one knowing how hard it is to get a non exchange replacement at present.
Engines use a liquid take off not vapour.Most lpg fork lift trucks have the bottle fitted horizontally , Can't see how it could be dangerous with an empty one.BUSBY.
A forklift bottle is designed to be on its side with a liquid take offMost lpg fork lift trucks have the bottle fitted horizontally , Can't see how it could be dangerous with an empty one.BUSBY.
It’s deffo LH thread, I’m away in it at the mo and it’s in use so can’t check exactly but I think stealaway is correctMGDavid, what is the connection for the Intermarche cylinder please?
Calor don't do a 9kg so which size do you mean.I need a french cannister that is same width +/- a few cms to that of a a 9kg calor due to size of gas cupboard. Any suggestions?
I struggle to understand your reluctance to consider refillable? I would not want an empty 11kg Calor rolling round my garage or the hassle of finding a French bottle on arrival and you are going to end up with a permanent need to store 3rd circa 11kg cylinder somewhere at home or in the garage on your van (Meaning unnecessary weight behind or over the rear axle).I’ve looked into refillable but for various reasons it’s not the best solution for us. Thanks anyway.
Sorry, I meant 6kg calorCalor don't do a 9kg so which size do you mean.
I would have fitted an 90° elbow for the right bottle. I don't like the look of the bend in that pipe.
