- Apr 13, 2012
- 5,960
- 20,508
- Mobilvetta Euroyacht
- 1996, then break 'til 2011
Got 4 of the bloody things on my property 2 in driveway right where wheels go and 2 in pathway by my backdoor - not amusing when they back up either although southern water do sort issues quicklyAll drains were adopted by the water companies some time back.
Providing more than one property uses said line.
It used to be only terraced houses.
This is the case in England I don’t know about the rest of the U.K.
My drains have other neighbours properties waste going into them anything could be going into the system - and i end up with problem everytime as they are on my property - just got to accept and live with it thoughOnly two reasons for drains to back up.
Poor design/maintenance or incorrect materials going into it.
Jacked my transit van up when it fell through manhole scaffold board under wheel and over drain - drove transit out - once up easy no burnt out clutch or anythingExactly the same happened on our drive, fortunately my breakdown cover did agree to assist. It took two RAC Van's to pull our 3.8 ton van out. My God did their clutches smell !!
Can't remember who the insurance cover was with but they used the RAC service.
We were moving house the following week so only replaced with a cheapo galvanised one.
Should of contacted the water supplier if other properties run through the drain they will replace it for free my transit went through the one on my drive - waterboard came out and replaced it no cost at all - not sure if they would do it if no other property runs through it though
My trolley jack is not high enough either i had to use axle stand to support vehicle then used packers to get it high enough to enable me to slide scaffold boards under wheel i was careful doing itThe grey water bloke came by late last night. He looked into the hole and confirmed that as a shared drain, it was their fault and they were very sorry!! He said that the 6mm steel plate I had laid over it was easily strong enough to hold 5 tonnes, even parked permanently, square over the hole. Easy for him to say, it's not his holiday home.
Anyway, he said that a crew will be out to replace the drain covers and reinforce the surrounds, and did I want heavy duty 10 tonne steel covers?
Hmm, let me think...
I tried this on my trolley jack, but the wheel wouldn't clear the hole so I could slide something under it. Mrs DDJC, (who is very protective of the bus), hinted that she had little faith in my technical perspicacity and suggested that I stop sodding about and get someone who knows what they are doing, if I wanted to see tomorrow's dawn.
I'm old get over itWater Board lol, there ain't been a Water Board since 1989.
