- Dec 2, 2019
- 5,359
- 12,236
- Rapido 7065+
- Broken most bits now
The way you've done it is fine but the distance should be either 67.6mm (115PCD/1.7012) or 76.4mm (130PCD/1.7012) for the standard Fiat wheel sizes. The 71mm you've measured doesn't seem to be close enough to either value so maybe try to get the measurement to be either 67mm or 76mm even if you have to close your eyes a bit to make one measurement fitHi dunnah01, I was told to measure half way between two centres 71 for the light chassis or 78 for the heavy chassis, by the Wheel shop , if you have a look at Newfi's post the calculator tells you to measure the two points and times it by 1.7012 which gives you 120 ,so what's the best way to go as I will need one it the next 2/3weeks
