Blown inline fuse (1 Viewer)
Gobcob
5
Chausson 640
Hi,
Wondered if anyone could offer advice on persistently blowing 15amp inline fuse from solar panel to vehicle battery?
Chausson 640 Titanium, 2020.
Cheers,
Grant
Jul 13, 2008
3,743
3,926
Low profile
w2f
Electric problems very difficult to solve without actually looking at it. Do you have a solar controller fitted?
Oct 8, 2014
1,644
3,034
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
How big is your solar panel?
Lenny HB
53,693
150,966
On the coast in West Sussex
Hymer B678 DL
Could be the solar controller is faulty and giving out a too higher voltage so in turn the battery is drawing more current.
You need to check the voltage coming out of the controller and also check it in bright sunlight. in bright sunlight. It should be a max of 14.4v (14.7v for AGM) if it's higher than that it will damage the battery.
G
Gobcob
5
Chausson 640
Thanks - original fitter has agreed to send a replacement controller so will try that.
Sep 29, 2007
805
1,167
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Even with a new controller if you still have things blowing you need more info. A clamp meter will tell you what current you’re passing through the fuse.
Also, make sure you’re using good quality fuses - don‘t skimp on that.
Sep 17, 2017
5,523
10,323
Birmingham, UK
A-Class
A 150w panel on a really sunny summer's day with a depleted battery is going to be pretty close to 15amps. I thought solar panels could output more than their rating for short periods if they're cool.
The TT's
Autocruise Rhythm
Having same / similar issue.
PV Logic MPPT Pro controller. 200W Solar.
Leisure battery is AGM, vehicle is, well, a vehicle battery so normal lead acid I guess.
Up until this week was only using the first battery terminal to charge leisure battery from Solar. Garage just fitted second set of wires from vehicle batter to second set of terminals (which only charge when battery attached to the first terminals is in a good place!).
They are fitting 10A fuses though.
Fuse has blown twice in 24 hours.
Just restarted the MPPT Pro controller as I noticed it had something 160 days uptime, just in case it only 'checks' some config on startup as was treating both batteries the same but just clutching at straws!
Did you get anywhere?
Sep 17, 2017
5,523
10,323
Birmingham, UK
A-Class
200w is going to pump a lot more than 10A on the 12v side. Are you saying they've just doubled up the wires? The majority of the current will take the low resistance path.
The TT's
Autocruise Rhythm
Just managed to locate the manual online, and perhaps have somewhat answered the question! No idea why they fitted 10A! Might be relevant to OP if they have 15A fuses fitted.
Relevant section below:
This controller is designed to prioritise the battery connected to the ‘Battery 1’ connections first, before then allowing a charge to the battery on the ‘Battery 2’ connections. In practice this means that battery 1 will be around 70% + charged before the controller will start charging battery 2. It will then bring the batteries up evenly to a full charge.
Please note: If charging two batteries that are interconnected on the same circuit (eg in parallel) only connect one battery to ‘Battery 1’ and do not connect the second battery to ‘Battery 2’. Battery 2 connection is only for charging a completely separate circuit with a battery on. For example the engine battery of a motorhome.
Jan 7, 2017
5
10
Fareham, Hampshire
Burstner
Since 2016
Hi,
Cheers,
Grant
Hello, had same problem, came down to smart alternator. Had isolator switch fitted to vehicle battery charge line from MPPT which I use before starting engine then back on again when parked up.. Otherwise blows every time when engine runs.
Oct 25, 2022
170
176
Infinity and beyond
Burstner Lyseo I 726
A very long time
I've a similar problem. Is your vehicle a Fiat Ducato and do they all have smart alternators? My 20amp fuses to both the starter battery and every now and again the leisure battery blow. Could it be the alternator and do I need an isolator switch on both separate feeds?
