Blown Bulb Warning Light Won't Turn Off On Dashboard. Still on.
Somerset
Nuevo called Mabel
newbie learning fast and sometimes the hard way
Have a Nuevo on a Peugeot 2.2 base 2007. Had the blown bulb light appear on the dashboard, tracked down to bulbs had blown, number plate and high level running light, duly changed the bulbs with new ones expecting the light to go out. Have checked every bulb inside and out and the are all working. Hand book say to refer to chapter later on, which only tells you how to change the various different bulbs. Any suggestions what might be the problem of how to get it off
Thanks in advance
On our Ducato the warning light doesn’t just relate to bulbs - in the handbook it’s called a generic warning light and there a list of things it could be showing, including fault in fuel filter sensor.
Thanks in advance
Ex lorry driver, when picking up trailers fitted with led bulbs, warning lights would always come on!
Yes led/canbus bulbs even tiny side light or number plate one's are a pain, as I had with lot's of car's over the year's.
So replace all these, or even try swapping the smaller bulbs as sometimes these can go into fault mode. I had my indicators miss a beat intermittently and tgis would bring a bulb out warning, so I've fitted the silverline bulbs I had in stock, deletes the eggy effect, look's a lot better, and not happened since 👌
Also as a matter of coarse upgraded the 55w osram head (dipped) to night breaker 200% better light.
Will post a photo of silver indicator bulbs later !
