We are on our 3rd van with gas only Truma, €450 for a couple of low wattage elements, it pays for a lot of LPG.I have also met people with German Vans, that have the German spec, Gas Only for heating no Electric element.
A system service, troubleshoot and complete fluid change at Alde in Wellingborough cost a bit over £200. -£40 a year not too much to pay.The Alde should be good....made in Sweden, I think. However, the Alde, being a wet system needs more maintenance. Topping up and replenishing the system every 3 or 5 years sounds like a chore. And how easy is it to repair, if the pipework/radiators start leaking.
Think I'll stick with the virtually maintenance-free blown air Truma, thankyou
Have a look at this thread.I see some people mentioning diesel heating, I assume you are not running your engines?
so what is the diesel heating and is it a retrofit or does the van have to come with it?
A fluid change every five years is hardly a chore given the rest of a motorhome that needs more regular maintenance. The Alde is based on a single 20mm aluminium pipe circuit that runs from boiler flow, around the vehicle, and back to boiler return with attached pump. Radiators comprise sections of the same pipe with aluminium fins other than the shower room radiator that has a loop of pipe inside an aluminium casing. Flexible rubber-material pipes allow for joints and corners. At each radiator there is a bleed valve. The major benefits of the Alde system are the pipework that requires very little space to run (it is pretty well hidden on my van) and the even spread of heat because of the number of radiators that can be installed. Mine has two radiators behind each bench seat, two under slots in the A class dashboard cover, one in the bathroom, four in the bedroom, one in the garage, one in the shower room and one in the kitchen. Add the underfloor heating in the lounge and bathroom areas and it has pretty comprehensive coverage. I should add that the van is approx 8M long. That sort of evenly spread heating is impossible to achieve with blown air (which I've had in every van prior to this one). Leaks are easily fixed if they ever occur but the regular fluid change should prevent any problems assuming correct installation in the first place.The Alde should be good....made in Sweden, I think. However, the Alde, being a wet system needs more maintenance. Topping up and replenishing the system every 3 or 5 years sounds like a chore. And how easy is it to repair, if the pipework/radiators start leaking.
Less than half a degree in my experience.less hysteresis in the temp control.
Nor either of ours. We had a Truma previously and an Alde now. The Alde is much better than the Truma, but gets nowhere near a half a degree between on and off. Can't see how it can when the radiators are still hotter than the surrounding area when the pump is switched off.Sadly not in ours
Our Truma blown air heating is excellent and Im surprised others have been disappointed by it. As others have said it must depend on how well it’s installed. Couldn’t really ask for anything better.
No.Have you had an Alde equipped van, for comparison?
Ian
I'm talking about AldeSadly not in ours
That is what I thought ................... until I bought a motorhome with Alde heating.Our Truma blown air heating is excellent and Im surprised others have been disappointed by it. As others have said it must depend on how well it’s installed. Couldn’t really ask for anything better.
I would not say I've been disappointed. Every caravan and motorhome prior to the one I have now has had blown air - first Carver then Truma. In every case we have been comfortable but in every motorhome the cab has been cold even with insulated covers on the screens. Prior to current vehicle we would never have criticised Truma heating. But Alde for us is a step change: there are literally no cold spots. The floor is warm enough to walk barefoot. The cab area is as warm as the rest of the van which means we can make full use of an A class cab with the seats rotated. This van has a heat exchanger from engine coolant to the CH circuit so all radiators work from engine heat as we travel - the gas is on too but never fires up. Also in the engine coolant circuit is an Eberspacher heater which, although I haven't tried using it for this purpose should run the CH via said heat exchanger. The Alde control has timed night-time set-back which means that settings made prior to leaving home aren't touched until we return. There's very little not to like.Our Truma blown air heating is excellent and Im surprised others have been disappointed by it. As others have said it must depend on how well it’s installed. Couldn’t really ask for anything better.
Our 2017 Chausson came with Diesel / Electric heating diesel fed from vehicle tank, we think it's economical, used it on and off last winter for 8 weeks In Spain used my UK bottled gas for cooking never ran out of gas, we think it's a great system, just wish it was all Alde !I see some people mentioning diesel heating, I assume you are not running your engines?
I have truma heating. Should I fit a thick curtain between the cab and lounge area to help keep the lounge warmer, and stop some of the condensation in the cab area?
You were informed correctly and it will indeed operate in this way. However, if you wish to conserve gas and utilise the site electric, I personally would switch back to electric only.I left it overnight.
It managed 18 in the lounge and 15 in the bedroom!
I have just turned on the gas and changed the setting to Gas 2 and electric and will see how well it warms up while I take the dogs for a walk.
One question.
I was told when I picked the van up that putting on mixed, it would use both gas and electric to get to temperature and then switch to electric only use to maintain temperature, only calling for gas usage again should it need to top temperature up.
I think someone else in this thread mentioned manually turning gas on and off, is this necessary or was I correctly informed on collection?
Robin
