Any ideas about numbness in the back side?
Don't take bad advice about super soft gel saddles. Look at the saddles that have just completed the Tour De France.Any ideas about numbness in the back side?
Same hereI think you need to see your doctor, it sounds like carpal tunnel trouble, that’s how mine started
Have a look on Ebay for a 'big bum saddle' ... we got them and they are brilliant, so comfy and don't impede riding.Don't take bad advice about super soft gel saddles. Look at the saddles that have just completed the Tour De France.
It's better to get the correct saddle and break it in, just like a new pair of shoes.
Phil
I go numb somewhere else and padded shorts don't help either,,BUSBYWe did the Tissington Trail on one day last week and Carsington water the day after.
We stayed at the CCC Ashbourne site.
Both rides are for us, long ones , cycled on an electric bike, so no massive effort.
However, on both rides I suffered both arms and hands rendered completely numb from the obvious vibration from the gravel surface.
This is made a little worse by quite a lot of weight , bike posturewise, still being carried on the arms.
I know this is a good thing for control and balance with off road cycling.
My ebike is a low end one but it has front suspension.
I compared the witness mark from the seals and could see that the plunge range of the forks was about maybe 40mm , so it's working.
I also suffer from numb arms and shoulders when sleeping, so probably it's me, not the bike.
We fixed this on the motorhome by replacing the mattress with a custom one from customsized beds , very comfortable, better than home.
Now, after all this preamble, the question I would ask, please, is has any Funster had a similar cycling problem and solved it with a new bike?
Possibly one with adjustable rate and damping on the front forks?
It's possible one needs suspension movement purely for off road ability and it confers no advantage in secondary ride comfort. ie. vibration from small regular surface imperfections still get to the handlebars?
I don't get a numb bum it's somewhere more personal,,It wears off after I get off my bike..BUSBY.Padded shorts work better than a gel seat. Plenty of riding will harden up your bum muscles. I also bought a wider seat with springs and that is a vast improvement.
I suggest you adjust your saddle angle.I don't get a numb bum it's somewhere more personal,,It wears off after I get off my bike..BUSBY.
Yes, that could work, or possibly a longer stem.Try changing the bars to a cranked bar that will raise the Bars a bit higher. This means that there will be less weight on your wrists
