2x2camper
- Oct 22, 2018
- 851
- 2,007
You'll have to if asked or you won't get on the trainYou can't at the tunnel if you wish to avoid quarantining having run through France ?
It does on mine have a look at the videoCan someone with a Ducato confirm if the rear doors will open with the Westfalia rack tilted. I have been waiting for over a month for an Altera Strada from Roofbox as they are on back order and could do with somethin for a few trips next month.
Ta
H
I have never been asked to do that on ferry or tunnelThe problem with that is when you have to open the doors fully for security at the tunnel or ferry
That rack is a mammoth! Amazing!
Must admit that’s what we had on our first PVC and it worked great but now that we have resorted to electric bikes we can’t lift them that high due to the weight.I recently fitted this Thule rack and love the fact that I can still open the doors with the bicycles on.
Stand on a foot stool,,BUSBY.Must admit that’s what we had on our first PVC and it worked great but now that we have resorted to electric bikes we can’t lift them that high due to the weight.
Being a couple of short arses doesn’t help either mind! Well I’m about average I suppose.
My gas bottle is in rear mounted storage box..so not a problem. BUSBY.Going via the Tunnel it depends how thorough the "gas bottle valve off" check is on that day. Several times I have been asked to open the gas locker for them to check the valve is shut, which does mean that both back doors have to be fully open to give access. Other PVCs might have a different location for the gas locker e.g. via the side door.
I think two e-bikes would be too heavy for the 35kg limt of this type of rack. My wife has one and it's about 19kg.Must admit that’s what we had on our first PVC and it worked great but now that we have resorted to electric bikes we can’t lift them that high due to the weight.
I agree, our two are about 40kg without the batteries. It takes the two of us to lift each one onto the towbar mounted bikerack anyway following Nick’s back and shoulder operations. I laughed when I pictured busby Idea of us lifting bikes standing on steps/stools. The health and safety elf (me) would have a fit.
That's only 38 kg for both then.Sure there is quite a decent safety margin built into the design. BUSBY.I think two e-bikes would be too heavy for the 35kg limt of this type of rack. My wife has one and it's about 19kg.
I must admit that the Westfalia ones that we looked at only tilted enough to partially open one of the doors on our Fiat Ducato IH 630RD just like out Thule whereas the Atera Strada DL3 slides out quite a long way and then tilts. There are quite a few Westfalias that tilt so it’s very confusing, none that we saw slid out first. I’d want to know the exact model and see it in action on You tube as they are so expensive. It does take away the worry about being searched at the ports, we always seem to get stopped.
you can add up to a 75mm spacer behind the towball to extend it. I used to tow three tonnes on a towbar with that much spacer without issueI’m looking to fit a tilting bike rack on the tow ball of our PVC.
I contacted The Roofbox Company, who say the Atera Strada DL3 should be okay. They can’t guarantee I’ll be able to open the doors, it depends how far the tow ball protrudes out the back of the van. In any case it will be close.
Don’t suppose you could supply me with a few measurements please?
in that case it will be a no, you can only fit them to flange type towbarsI’ll have to take a closer look at my tow bar to see if I can fit a spacer. It an Auto-Hak with a detachable tow ball.
Sorry for the delay but the rain has finally stopped! The critical measurements and I hope this is going to make sense from my photos. We have a Fiat ducato PVC 2019 model. The RHd rear door opens first so is the critical one. If yours is European and it’s the left then this is the one that opens the furthest out.You’re a star. The racks are out of stock at the moment, but I can put in a pre-order for one.
That’s a pity but at least you know.
