After fixing direct with Sikaflex, if the panel subsequently fails removal must be very difficult.
stick the new one directly ontop.....
stick the new one directly ontop.....![]()
[QUOTE="jonegood, post: 1500749,
I put the first one on with Sikaflex 2 years ago and it failed at the end of a trip in June. Ive no idea why it failed but it just stopped producing.
No big deal as a job and new one is working fine so far.
Jon
Jon
Did you get it replaced under warranty ? Just fitted a 150w unit which is working well, but since then I've read a couple of stories of them failing.
Looking at some of the pics, on these posts does anyone ever give any thought to roof maintenance.
Sky light re sealing, replacement etc, seems a good few don't, and have seriously compromised access to such things, giving aesthetics priority over practicability
Food for thought for those about to fit
G
It was a general observation based on the pictures posted of MH roofs, not specifically solar panels.I'm struggling to see how this relates to semi flexible solar panels. They are surely less likely to be in the way.
Minxy is quite right
I am talking where to put your knees or feet or tools when the need arises to fix or re seal a roof light or vent.
It was specifically but not exclusively solar Panels I was referring to.
I have purposely not pointed to any particular install as I see so many what appear (pics do lie) to be poorly thought out installs
and flexi panels have exactly the same foot print as framed one's so I am also at a loss why you fail to see the
connection (You shouldn't stand on either type)
If you stick Flexi or framed panels either side of a roof sky light you then loose the access to that roof window/vent from the sides, if its also near the front cap that's 3 access/maintenance points you've lost
if it also has a huge Heki light behind it your only access is to stand on your panels or remove them ergo an ill thought out install.
It may not look as aesthetically pleasing to have one panel a foot further back than its partner, but if it gives foot room around a roof item
then that might be considered a good or better thought out install.
The post was intended as advise and be food for thought to those about to venture into DIY panel or other roof installations
and to repeat my self, it is as relevant to Flexible panels as it is to framed panels as it is to Sat Dishes and Arials, If whatever you install makes roof maintenance difficult, think twice and install once
G
They don't work?Its not a problem in my case as they no longer workbut even if they did I wouldn't stand or kneel on my bare roof anyway, with or without panels, but a 2ft x 5ft rectangular bit of 18mm ply with 20mm of foam stuck to it protects both roof and panels
so as a matter of fact flexible panels make it easier to work on the roof than normal ones which you would have to remove to work on the rooflight
Sounds like he was giving good advice to me.hi all,
we would only have room for a flexi solar panal on the overhead curved cab roof due to air con and sat. using up all other space.
At Norwich we called in at the road pro stand and enquired about the difference between the high and low priced flexi panel they sold. Spoke to the owner who said, this is true by the way, "Well the expensive one is very good and the cheap one is rubbish!" why is that I asked, "the cheap one keeps stop working and the dear one does not".
What guarrantee do you get,, "well two years but you know what they are worth!" Not really selling us on them to say the least.
I have also read about over heating due to no air gap, can anyone update us on this issue and where they had them fitted
I did ask the road pro owner why he sold a rubbish solar panel and he said, "we tell them all about them and if they want to buy rubbish then that is up to them."
My friend and I decided he was having a bad day, by the way we did not buy from them.
Supplier has offered me a refund or replacement panel. Wary about a replacement in case it goes the same way. Can anyone recommend a 150 w flexi panel that isn't a Biard ?
