Concerns Over BFG KO2 Tyres Cracking (1 Viewer)
Oct 5, 2019
417
310
Southport, UK
autotrail
im a newbie
hi i have a set of bfg ko2 all terrain tyres they are just over 2 years old, and 2 of them, showing signs of cracking on the side wall, has anyone else came across this? ,,roque alloys where i bought them asked to send pictures ect now they not answering my emails ,,they said the wheels are warranted for 3 years ,,but the tyres dont have any warranty ?
Jan 13, 2014
3,618
11,613
Leeds - Yorkshire
Off Piste slightly but l have just replaced BF Goodrich as l didn’t really need such a serious off road tyre and the roar that comes with them.
Gone for Michelin CrossClimate 2, 10ply not the Camper ones and the date stamp is 2024 so only manufactured a ot 3 months back.
They are very good indeed and the roar is silent by comparison.
Just saying🙂
Jim
Ringleader
Jul 19, 2007
36,514
131,367
Sutton on Sea, UK
Adria Panel Van.
Since 1988
If they are two years old you are probably soon to realise how bad they are in wet road conditions! That said, people are saying the compounds have changed somewhat and they are fairing better. But don't go throwing it to any hairpins in the rain :D
Gellyneck
9,265
18,409
Scotland
More than toes wet now!
Not challenging but the first question I thought the supplier would have asked was "are you running them at the correct inflation pressure" as wall cracking can / will occur if not.
PP Bear
7,842
28,922
Kent, UK
Auto Trail Dakota SE
My original Michelin tyres were all cracked on the sidewalls and had miles and miles of tread wear left in them. Possibly lack of use, parked up for longer periods of time and damaged by the sun. I changed them for another set of Michelin Agilis which lasted a full 10 years, as recommended by Michelin themselves, but used regularly, 80psi all round, check religiously for any signs of wear, psi or cracking and then replaced by these.
I used to be a tyre fitter, so was very keen to examine my 10 year old tyres, both inside and out and they were perfect, in fact the tread had plenty of wear still in them, but I followed the manufacturer’s recommendations of 10 years.
So far I’m loving my new tyres, but time will tell 👍🏻
I’d get yours changed, checked regularly for correct inflation and either use it lots, or lots of short runs to get the tyres rotated and not parked in the same spot.
5,427
21,681
Cumbria
since 2011
Going by the date code on the sidewall, they were made in May '21, so were probably a year old when you got them, not that should affect the cracking, but I would have expected some sort of pro rata refund from the seller dependent on the mileage you've done ?
Jim
Ringleader
Jul 19, 2007
36,514
131,367
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I had some Michelin tyres on a van I bought that were 13 years old! They looked great. Very few cracks and an almost new level of tread depth. Except, you may as well have been driving a Fred Flinstone car. They had sort of fossilized, the compound had gone literally rock hard. They had no grip at all on the road and would spin on damp grass! Looks aren't everything when it comes to tyres.
382
632
Humberside
Geist Phantom
MoHo since March 2018.
I used to get that with new Michelins on my Saab, put me off them. God forbid you got on a white line with them lol.
I am aware this will be car/model specific and not something others may suffer from 👍
rob1234
Oct 5, 2019
417
310
Southport, UK
autotrail
im a newbie
hi i did an online check weight ,,tyre size ect ,,ect and was advised of what to run them at ,,i found the ride brilliant compared to the standard michelins ,,
rob1234
Oct 5, 2019
417
310
Southport, UK
autotrail
im a newbie
i too was in tyre fitting many moons back ,,the were kept at the advised psi,,one tyre is split all the way round
4,971
17,375
Todmorden
Van conversion
FUNSTER in a PVC
Can I ask ‘what mileage have you done on those tyres?’
rob1234
Oct 5, 2019
417
310
Southport, UK
autotrail
im a newbie
roque alloys ,,saying there is no warranty on them ? i have contacted Michelin my self ,,who said take them to your nearest michelin dealer for assessment
70
26
Cambridgeshire
Burstner 747 - 2
Hi I have to change all my tryes as well, are you saying these tyres Michelin 225/75/R16 Cross Climate are as good as any others I'am lost with all the good and bad comments.
70
26
Cambridgeshire
Burstner 747 - 2
I’m reading good and bad on forums so no better off in choosing really?
I think I need Michelin Cross Climate 225/75 R16 CP are these as good Continental?
PP Bear
7,842
28,922
Kent, UK
The first set were cracked when I brought the van second hand and had been fitted from new and 6 years old and 11000 miles. The set I then put on and ran for the 10 years, covered approximately 40000 miles. They carried on performing well, even in the wet, but as the manufacturer said change at the recommended 10 years, I did.
The newest ones I only had fitted a few months back and probably 2000 miles so far.
All tyres kept at 80psi.
297
199
Devon
Hymer
since 1999
I also have the Bf Goodrich Ko2 and i had a advisory on this years mot for tyre walls cracked. Our tyres are three years old! The garage said it was down to lack of use and mileage but nothing to worry about..
Jim
Ringleader
Jul 19, 2007
36,514
131,367
Sutton on Sea, UK
Adria Panel Van.
Since 1988
The tyres are designed to run almost flat when in mud, so that might necessitate a softer tyre wall, I've had mine down to 12psi before now, they are a great tyre on a 4b4.
I suppose BFG's are famous for three things, being awesome at low pressure in mud and rock, sidewall cracks and splits and letting go in the wet, why people put them on motorhomes is beyond me.
4,971
17,375
Todmorden
Van conversion
FUNSTER in a PVC
Isn’t it because many people get concerned that they will get stuck in a grass field so spend a fortune on tyres who’s resondetra is traversing over rough ground, yet they spend 90% of the time on Tarmac 🤪.
I thought about them but have decided just to get 16ins Alloys and Conti 4 season tyres when my current tyres give up.
Jim
Ringleader
Jul 19, 2007
36,514
131,367
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I think everyone saw Gadget John fit a set. :D That said... Plenty of dealers are fitting them now too, they look good and are relatively cheap. I have heard that the BFG K03 are much better than the KO2, but I've no experience of them
rob1234
Oct 5, 2019
417
310
Southport, UK
autotrail
im a newbie
ok did they say why they advised it ? if its nothing to worry about ,
