Best Small 200w-300w solar panels please?
HYMER B644
I only have 80cm wide but can go to 260cm and 160cm
Any suggestions please?
These seem okay //........
2 x 200 w £240 with Ebay voucher
or these 300w but seem small for 300w
£160 each or £320 two
This is a good deal, and very good panel made in Spain under Burger Mayer manufacturing design and superior machinery.
what do you think of this one Raul please ?
Sorry, Raul I mean this one. Did I Link the wrong one!
That is the flagship panel they do, top con (oxide coating) and rear cell bus bar, very efficient ultra high quality in that class, top panel.
Again if space allows, don’t hesitate.
may I ask how you fixed them ?
I used the aluminium rails and screwed caps system that is standard for domestic roof installation. I used Renusol kit, because I’ve used it before, there are others. Their online catalogue explains how it works - that’s how I learned. I fixed the two rails to the 8 roof rack fixing points that Ford supply on the Transit (deep tapped 8mm holes) using Renusol flat roof angle brackets. Due to the cantilever (overhang) at the rear I pop riveted some Ali angle to stiffen the Renusol rail. Did the same to the leading and trailing edges of the panels, as I suspect at high air speed vortex shedding will cause vibration and bending. So far (7,000 miles) so good. The domestic panel installation kit is very high quality - generous sections, high strength Ali alloy and stainless steel, made to last 50 years. And easy to install, designed for unskilled guys working on a pitched roof in a gale hanging from a harness. I’m sure the others are just as good, it’s a very competitive market, I’ve used Renusol in the past so know the system and had loads of off bits left over to use up. I see 400W panels are now £70 ex VAT.
May I ask what size cables you are going to use from Panels to Solar Controller Raul
6mm ? 16mm?
Spec on the Victron SmartSolar 100/50 states maximum power connection AWG6
From panels to controller 6mm2, from controller 100/50 to battery 16mm2, but in my case it’s only 600mm long. If your controller is over a meter away, then 20mm2 cable or 25mm2.
The 20mm2 is hard to find, but exists.
If you fit more solar the controller will almost certainly need changing as a dealer will fit the cheapest they can get away with…
I have two exide e900 gel 85ah batteries so not much more than what power you have but I have two 200w panels and a victron 100/30 mppt controller and I’ve never had to plug in to EHU and I go away for 3 months…
Thanks, great to hear and I’m aware of Victorian but good to have the model recommended and the real-user experience. Many thanks indeed 👌🏻👌🏻
Flippin auto correct! Victron of course… 😂😂
I had to go with this one in the end as that 480 was just a few CM too long
Can I ask another question please? I re-read your reply to see which version of Victron you bought and noticed you went for 2x200w panels as opposed to 1x 375/400/430 etc like I’ve been looking at, is there a specific reason or benefit or a fitting logistics reason? Im really not clued up on these things 😳. TIA
I could have put just one panel on but my thinking is that if one panel brakes or is in shade then I’ll still have some solar from the other, plus I think at the time I couldn’t get one large panel the size I wanted at the max watts I needed..
Worth knowing that, this newer half cut cells large panels, are behaving like two panels in parallel. If one end is in shade, it will not affect the other half. Also the 3 bypass diodes fitted to this panels, it will bypass the shaded portion, making the entire panel into 6 individual working areas. So, if any shade is on any of those areas, it will be bypassed by the diode, allowing the rest of the unshaded areas to work unhindered.
I hope this makes sense.
And yes, we make our choices, based on the availability of the time, I understand.
Panels are certainly improving all the time Raul…👍🏼
Can I ask what controller you’re using please, and what battery(s)? TIA
Victron MPPT 100/50
From
RogerIvy
Fogstar drift 105 also available from
Both can be ordered with motorhomefun discount
I wish I was more practical! Can anyone recommend someone in or around Surrey who can supply and fit a solar solution. My MH came with a flexible 100w installed which is no longer working. Only looking for something that gives me peace of mind when off grid for 3-4 days with light usage to keep the 2 leisure batteries topped up.
Has your panel arrived yet? My 2x 400w arrived today. I have to say I’m impressed, 400w in a size that used to be 230w 10 years ago. The buss bars are like a matrix at the back of the cell, not at the front, the cells have no space between them, and no solder, means no hot spots. Very slick 30mm black frames, and Staubli mc4 with double seals.
I hope for no rain on Sunday morning.
It did arrive last week.
Currently stood in my office.
I am awaiting some other bits and bobs and good weather.
I have removed the old panels and sikkafkex.
But I am off to Spain tomorrow , going to get them some rain !. Just as I am getting solar fitted on our house there. LONGI 510wp panels.
The panel Eurener looks very high quality !.
I will post some photos when it’s on !
I also considering 400w single panel if I can fit it on ! so much cheaper
But they are designed for domestic use I think
Is there a difference domestic / motorhome solar panels. ?
Domestic ones are larger starting at 200 Watts for the smallest and work at higher voltage 33v to 45v and they tend to be more efficient.
Raul is the man to give you full info.
