Best last-ditch physical security mechanism? (1 Viewer)
Apr 3, 2024
59
86
Fiat
We've got an alarm, an immobiliser, etc., etc. But of course, with a high-value vehicle, there are those scum out there who can defeat all those measures. So I was thinking of getting a last-ditch additional barrier.
I'm not keen on a wheel lock as I don't trust the scum to spot it - and if they drive off in a hurry with it still in place it'll probably cause loads of damage.
My first thought was a steering lock. But when I put my thief head on, I would take a portable reciprocating saw, cut through the steering wheel and I'm away. It would probably take about 20 seconds to defeat a regular steering lock, depending on whether I had to make one cut or two.
In discussion, a pedal lock was recommended to me as being better than a steering lock. Again, with my thief head on, the best of them seems to be the Milenco that boxes the pedal in - so you can't just cut the pedals off and slide the security lock off. But it looks like I could still put the saw blade behind the box, cut the box off and again, I'm away. Yes, it's a bit awkward pushing on the cut ends of the levers that once had pedals attached but if I was that way inclined, I'm sure it would be driveable far enough to get it away.
The only one that I don't know how I would defeat is the steering lock that fully encloses the entire steering wheel. But they're damn expensive. And big, too.
When I was a student I had a nasty old Escort which I would park in Birmingham. I routed the low-voltage ignition feed through three switches hidden under the dash. You had to get all three in the right position or it wouldn't start. I'm starting to think that something like that is best. Or taking the distributor arm with me!! Not sure what the modern equivalent is!
Any suggestions?
funflair
20,039
32,933
Guisborough
MORELO palace
since 2012
Removable steering wheel (y) OK they could take their own but would need to know what fitting ours is and you can't just buy them over the counter.
Jan 22, 2013
1,341
73,300
London SE
A class Adria vision I707
since 1971
Removable steering wheel is a non starter for the majority of modern motorhomes as they incorporate an air bag in the centre,
A visual deterrent is the way to go, stop the toe rags from deciding to break in the first place,
Jun 29, 2015
3,680
61,310
Southampton
caravan (for now)
on and off since 1984
Any suggestions?
I'm having a Ghost immobiliser fitted, with it the engine won't start until you press 4 buttons on the steering wheel in a set order.
Oct 28, 2022
592
1,219
Rapido
Any suggestions?
£150 for a disklok, surely a small price to pay for a high value MH? Much cheaper than trackers which we all have to have for insurance?
Also, think outside the box? Engine immobilisers? Im not giving away my secrets on a public forum btw…
Security post is worthwhile, i scrounged one from my employer, so only cost me a bit of concrete and a padlock…
Feb 12, 2018
848
5,666
South Yorkshire
Adria Coral 600SL
Since 2017
That seems to lock the gearbox in one gear, but why can it not be driven off. even if slipping the clutch is needed?
Should be fun if left in reverse! :unsure:
Seriously, the best you can do is have visible and audible deterrents which make another nearby MoHo seem to be a much easier target and accept that the long-stop (hopefully never needed) is the insurance cover you bought.
funflair
20,039
32,933
Guisborough
MORELO palace
since 2012
Works on ours😏 A class with modified dash don’t have air bags.
jumar
4,112
13,270
Spain
Hymer Tramp
Since 1994
Really Martin...no Airbag...that's a first for me...other that Heavy commercial vehicles...and my motor scooter..
funflair
20,039
32,933
Guisborough
MORELO palace
since 2012
Yes N+B do on the Flair because they don’t alter the steering wheel position but Morelo and Concorde move the dashboard further forward and move the steering column so can’t use airbags.
Aug 14, 2016
52
43
Auverne Rhone-Alpes
Ford Transit 1984
April 2016
Any suggestions?
This won't stop it being stolen but might help it being found. I've bought 5" numbers & letters and stuck the registration number on the roof. It should help the police helicopter find it (yes I know they'll be too busy) but also plod could look up there and I doubt theives would.
MisterB
6,706
15,436
Essex
Adria 670 SLT
Vanbitz immobiliser, but also consider clutch claw as avisual deterrent
from what i understand, no motorhome has ever been stolen with the vanbitz immobiliser, when its actually been on, though there have been a few attempts, all foiled .....
Feb 16, 2020
538
1,601
United Kingdom
Dethleffs Globetrott
Newbie
We installed and use all of these as and when we feel they are required (which is most of the time)! A non starter, immobiliser, trackers, alarm, disklock, pedal lock & wheel clamp.
Visual deterrents as well as non visual will help, they may only slow them down, but it may give you/someone enough time to discover them and take action.
Jun 30, 2022
676
4,154
burstner lyseo 590
March 2022
We have done the same 👍🏼
Aug 3, 2021
50
44
Hymer I580
Any suggestions?
The new Disklok is supposed to be very difficult to remove, probably the best steering wheel lock as the thief can’t get at the body of the steering wheel to cut the lock off. As you’ve commented it’s impossible to make any vehicle 100% thief proof, but anything that slows a thief down acts as a deterrent.
Jul 8, 2020
34
73
Don't yet own one
Newbie
Any suggestions?
Can't really help you. Talking of old Fords though, the MK1 Fiesta I once had was the best. There was a real knack to starting it & one mistake flooded it. Then it was a good 5 minutes wait before you'd have any chance of another try.
It totally defeated thieves who hot wired it on at least one occasion. Who needs security devices!
DBK
18,426
49,821
Plympton, Devon
PVC, Murvi Morocco
This is our deterrent of last resort. Unfortunately, it can be disabled with a biscuit...
Feb 5, 2024
177
323
Etrusco CV540 DB
I have deadlocks all round, a Rewire tracker, a bar type steering lock, motorcycle disc locks to lock the seats in a position whereby the backs block the side windows, and a modification which disables the auto gearbox. If I told you how I did that I would have to kill you so it will remain my secret. It means they might start the engine but they ain't going anywhere!
May 7, 2017
2,092
2,452
Suffolk
Chausson 788
20 years
As said before thickish high tensile chain around suspension leg through wheel locked with heavy £80 high tensile pad lock, ( using portable hand grinder I can assure you you would need a few discs to cut it off) hopefully somebody / neighbours would here noise if we are out . Would they nock a Transit knowing the cambelt in oil problems,and injector problems ?😂
May 24, 2022
54
86
Converted VW Crafter
You say you have a immobiliser but we have an S5 plus tracker too. This means that even if the van is picked up e.g. tilted to put on a trailer without starting it, it will notify a call center who will ring us and then the police if need be.
