Thanks for all the helpful and informative replies, hopefully I'll be fine and none of this will be an issue but better prepared.
£45 ????We use a Colapz USB rechargeable pump like this
Cheaper other USB charging options are available too£45 ????
You can get a diesel transfer pump complete with cigarette plug for circa a tenner.... just need bit of hose....
where do you find the space to take a aquaroll in a converted van when we had one they wasn't room to turn around in oneYOU have opened a can of worms here...
3 options
Hose
Water can
Aquaroll..
I personally have aquaroll with a submersible pump that you can plug into 12 socket in van thru window... cheapest I found... search for diesel submersible transfer pump... (not a wind up).
But as I say, some swear by the hose route or the run back and forth with a watering can which you still need to lift up to filler. Take yer choice, but as I say aquaroll for me..
Book a fully serviced pitch they come with a water tap and grey waste disposal, although you will need a hose to fill and something like a Collapz pipe system. That way you don't need to move ( serviced pitches do cost more though)We are going away to Salcombe in July for a week, I'm trying to work out how to refill the the water tank whilst on site. We will have to use the water for everything but drinking, we will take bottled water for that. We have a 2009 Pilote G732 which has its water intake halfway up the side of the van. I have several ailments which occasionally make the physical side of life quite awkward and am concerned about how to refill the onboard water tank if I'm feeling less than capable. The Boss has bought windbreaks and a 7m skirt to keep the hounds confined and I'm not sure if moving the van once setup is a viable option.
Is there a way to use a Aquaroll or similar and some form of electric pump?
Is having metres and metres of hose a better option?
Or something else?
Many thanks, if this has been asked before ( I did use the search but couldn't see anything that I thought related to my situation) I apologise .
