Battery Terminals
wotme
new forest
Sold it!
I'm a newbie
I thought it would be easy enough to identify the negative terminal of the starter battery on my Fiat Ducato but I cant see anything that resembles an earth connection. I would love to go on a run to charge the battery but I have no choice other than parking it on grass which is too wet at the moment to get traction so I need to use a charger. Can anyone help and tell me if the negative terminal is nearest the front of the vehicle
Thanks so much.
I disconnected the "odd one out" retrofit output (where you have the 60A fuse) which removed power to the CBE box input B1+. I then ran a parallel cable of the same section via a different route and connected both.
Success that I can now get 33A into my 100Ah Lithium having reduced resistance significantly.
Problem that I now have a yellow "Engine" icon light on the dash so i am wondering what I have upset or what else was connected to this.
I am going to upgrade the CBE box to Leisure battery cable next to cut resistance a bit more. This is an 8mm cable but goes a long route and drops 0.2 of the 0.8 volts.
I feel I should really run a separate Alternator to Split feed perhaps when back from travels.
Cheers.
R
Thanks for all the info
So now with the parallel cable and reduced cable run resistance we are up to 33A charging current.
or rather were, as we now have a yellow "engine" icon on the dash, and no D+ so no split relay and its not the fuse in the CBE box.
any ideas ?
thanks
Richard
