Battery Master not trickle charging? (2 Viewers)
Dec 20, 2013
412
675
Kilsyth, Glasgow, UK
I have a Battery Master connected between my Fogstar underseat Lithium hab battery and my vehicle battery in my Fiat based Chausson 711 Motorhome. It doesn’t appear to be topping up my vehicle battery and it eventually discharges due to draw from a tracker and alarm. The in-line fuse is fine, but the red light on the Battery Master is not lit - but don’t know if it only lights when topping up! The Lithium battery is fully charged but the vehicle battery keeps discharging. My 230v hook up only charges the Lithium hab battery.
Any ideas on what the issue might be?
Dec 5, 2022
162
163
Lichfield, UK
autotrail navajo
4 yrs
Green light good, red light topping up start battery, full operating/wiring instructions readily available on line
Kannon Fodda
2,881
8,785
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
Obvious first step is to check the wiring connection of the battery master. Is it across the starter and lithium batteries at say a b2b, relay or similar point. Black = common negative. Red = Leisure positive Brown = engine positive.
Green led no charge, red led charging.
Kayak Kid
Dec 20, 2013
412
675
The Battery Master is wired between the two batteries as per instructions. It isn’t wired through the B2B. There are no lights at all showing on the Battery Master.
May 31, 2015
12,461
51,117
Ducato PVC
Getting Better
Wire your battery master like this doesn’t matter what b2b you have it’ll be the same….
Kayak Kid
Dec 20, 2013
412
675
I have a Victron B2B but Battery Master is not wired through it! Is that the issue as I thought the BM could be wired battery to battery?
May 31, 2015
12,461
51,117
Ducato PVC
Getting Better
The way you have it is ok and how it’s done if you don’t have a b2b but putting it on the b2b is easy and all in one place, no long wires to the BM..
Apr 27, 2016
7,403
8,829
Manchester
A class Hymer
Since the 80s
The BatteryMaster comes with short wires already attached. At the ends of those short wires, it will be wired to other wires or to a device terminal. It sounds like in your case it is wired to other wires to extend them to the batteries. You need to get a meter on those connections at the end of the short wires. You should get the two battery voltages at the two positive wires. If not, you should check for bad connection/blown fuse along the wire to the batteries.
eddie
8,343
42,850
Taunton Somerset
RV
since 1989
It was wired battery to battery before I installed the Lithium and Victron B2B! Did it a while back so can’t remember what I did at the time. -so will need to check! Why do you ask that?
Having designed it and sold tens of thousands of them, they very rarely go wrong, genuinely
If no light on normally a negative connection fault
Kayak Kid
Dec 20, 2013
412
675
Thanks Eddie - I will check the connections when I get the chance as building an Alpine style car port over my motorhome at the moment, and trying to make the best of the good weather.
Jim
Kayak Kid
Dec 20, 2013
412
675
Cheers - thanks for that. Will check it out!
Jim
