Yes we are![]()
Then off grid solutions are giving you good information and giving you the options, it’s down to you but I would definitely take their advice, not only are they very good fitters but they also are incredibly knowledgeable….
Yes we are![]()
The overwhelming response is to go for it, so we areThen off grid solutions are giving you good information and giving you the options, it’s down to you but I would definitely take their advice, not only are they very good fitters but they also are incredibly knowledgeable….![]()
They’re having a top of the range system fitted by Offgrid. The Battery Master will only add about £80 so seems daft not to. They’d then have all that faff. BM is just fit and forget if you’ve got proper solar panels.Why not just get a small trickle charge solar panel? We have one just to keep the vehicle battery topped up while parked up. Only about 20 quid from ecoworthy.
No you are correct but battery maintainer/master choice depends on what you want it to do, a battery maintainer will keep your starter battery topped up when you are on solar or hook up as will as battery master but a battery master will keep your starter battery topped up from the lithium without any solar or EHU (most of the others won't) our van is stored in a shed without solar or power so the lithium batteries are isolated from the van as the panel etc takes a good chunk of power, the battery master is fed from the lithium battery side of the isolator so yes there is a risk that we deplete our lithium but calculations have been done and the van will be parked up for 3 months and will be OK when we get homeWhen in storage are you under cover? On ehu? If not you can seriously deplete a lithium hab battery. My understanding of how they work is that the lithium will always have the necessary voltage differential to keep it filling the cab battery to the detriment of the lithium. I would love to hear that I’m wrong as I have one sitting in the cupboard![]()
Depends on your controller, some charge bothif you have a solar panel, then a Battery Master should be part of the installation.
No point in charging up one battery when you can change both!
Not quite right.I presume you have a Battery Master or a similar switching system to balance the load then.
A Battery Master is also usually set up to charge the engine battery first and then charge the leisure batterie(s)
Once all are full keep them all topped up from the solar panel.
Same with us. The draw from tracker and other systems is 0.6A which flattens the starter battery after relatively few days. The battery master means the leisure battery takes the strain first.Our solar panels are supposed to trickle charge the cab battery when the leisure batteries are full, but our brand new battery drained flat in 2 weeks of not using the van, with, AFAIK, only the tracker draining it - the garage couldn't find any other drain. This is the second time this has happened in 3 years so we're definitely getting a Battery Master!
That is true - I boult one and was happy with it. However the manual (and Votronic's website) is explicit that the cheap version is not suitable for Lithium due to the different battery voltages. BatteryMaster appears OK, as is the AbleMail one - I've just switched to that as part of Lithium conversion as it allows a bit more control over charge current.Votronic one is cheaper than another well known brand and works very well.
Where can I purchase a votronic battery master? and how will I connect it in my 2008 bessacar motorhome with normal lead acid batteries, would appreciate your advice.Votronic one is cheaper than another well known brand and works very well.
I know what you mean but clearly every motorhome dealer doesn’t share the same view.
We leave our car for 3 months every winter and it starts up every time we go home and runs/drives with no issues. I see no reason why a motorhome shouldn’t behave in the same way as long as the battery (ies) are kept charged
Not quite right.
A Battery Master, as in Vanbitz Battery Master, trickle charges the starter battery from the leisure battery only.
It does not and can not charge the leisure battery.
The cheaper Voltronic is not designed for lithium.Votronic one is cheaper than another well known brand and works very well.
I don’t have one but curious what about it wouldn’t work?The cheaper Voltronic is not designed for lithium.
Votronic call it a battery maintainer,Where can I purchase a votronic battery master? and how will I connect it in my 2008 bessacar motorhome with normal lead acid batteries, would appreciate your advice.
I changed that a little bit, but you may well be rightSurely a diode and a resistor and the knowledge to know what to do with them would work to top up the starter from the leisure battery. Pop a fuse inline for good measure.
B to B charging makes sure both batteries are in peak health. The batteries last longer and perform better. We had this type of charging on our last motorhome standard and have added it to the latest one. When the motorhome is stood doing nothing in storage at least the solar panel and B to B charging is working away keeping the batteries topped up and anything like a tracker is kept functioning properly.We're currently parked up at Offgrid Power Solutions to have lithium installed tomorrow. Roger has just mentioned fitting a battery master. Do we need one? We've never experienced low vehicle battery up to now. I can see the benefit, but are they essential? What do you guys think?
I don’t think I have. Must check.If you have a Votronic B2B you don’t need a BM.
Is it more the diode/resistor type arrangement rather than being microcontroller based ?
Hi. Mine seems to send solar to the starter battery irrespective of the condition of the leisure battery It sends 1 amp and is an EPever controllerIs it the case that it only sends charge to the starter battery if the leisure battery is fully charged or does it do both at the same time?
