- Apr 27, 2008
- 12,158
- 14,964
- Hymer low profile
- Since 1972
Apologies for duplicate post, not quite sure what happened.
Like the Rapidos mentioned above, my Hymer does the same... charges both leisure batteries and the starter battery too both via solar or hook up... (and of course the engine.)
Our old solar controller showed a red LED when charging, and a green one when charged.Anyhow... the red light on the controller now lights up but have no idea what this is telling me... the instructions are faded and in German!
The electroblocs
EBL99
EBL100
EBL244-9
EBL240
EBL269
do not charge the starter battery with the LRS1218 without additional wiring from it to the starter battery and same goes for any other regulator that may be plugged into it.
Yes the starter battery gets a 2 amp charge when on mains but not when on solar alone.
http://www.aireandsun.co.uk/pdf/solar_systems_and_electroblocs.pdf
These do
EBL101
EBL220
EBL220-2
EBL225
Link Removed
You can connect to the battery input terminal but for many the seat might need to come off
So which is the connection point for the starter battery on the front of a 99 etc?
yes..So where is the battery charge output? Underneath?
Very Useful, thank you.
no problem.. bear in mind these are Hymer cable colours .. can be confusing...
Red is Starter battery positive (conventional)
Black is Hab battery Positive
Brown is Negative for Hab Batteries
UK motorhome convertors will in all probability use conventional colours, Red and Black as Pos and Neg .. but always check with a multi-meter
Thanks again, ours is a Hymer so probably as you mention.
I have not had the unit out yet, but there seems to be a lot of excess cable coiled up under it.
yes, there will be enough slack to lift it clear to allow disconnecting cables.. don't forget to remove battery fuses before lifting..
I had mine out (hence photo) to send away for repair..
What repair did it require may I ask?
If you buy the LR1218, it is supplied complete with the required cable links to charge the starter battery when used with EBL99 or EBL100, or the later EBLs that work with LCD (DT) control panels. I have an installation to an EBL99 - both battery sets are charged, and the charging current is displayed on the meter in the IT992 control panel. (It was supplied and installed by Stephen at Aire & Sun last year - great job.)
