Bailey Approach Autograph 79-612v wiring diagram? (1 Viewer)
Alan+Marie
5
Bailey Autograph79-6
Hi, does anyone have access to one of these? or even a pinout for the pcb? Baileys sent the nicest "get lost" email I've ever had when I asked for one and the one in the owner's manual is shameful.
I'm not getting any power to the onboard water pump at all, fuses are ok, I can hear a relay "ticking" from a possible relay the fuse box when I select the pump on the control panel and the pump works when tested on a 12v supply. I don't know if its a relay or a control panel issue, but it's obviously top secret to Baileys as they wont tell me and just suggest taking it to a dealer. I would like to think the amount they charge for these motorhomes, they would be a bit more helpful.
Any help would be great, thanks in advance
Oct 9, 2019
5,087
17,928
Todmorden
Van conversion
FUNSTER in a PVC
You may find that there is no such thing, Bailey will tell you they cannot supply one as its subject to change too often šŸ„“
A
Alan+Marie
5
Is there a separate water pressure switch fitted that could be faulty or You could try www.bcagroup.co.uk who , I believe , supply Bailey with most of their electrical equipment , (but they may not talk to you either)
there is, and it works ok, a bit of a weird arrangement & it was one of the reasons I wanted the diagram, as chasing the wires are a nightmare
Apr 5, 2019
410
313
Low profile
I'm a newbie
BCA build the electrics and the board has stayed the same for a while - slightly different coding flashed to it - the board may have been redesigned due to compulsory smart alternator fitment (or minor changes to the wiring harness).
As to source for wiring and circuit diagrams :- https://www.facebook.com/groups/baileymotorhomeownersgroup/ and use the search facility (spyglass icon), plenty of info.
Jul 15, 2023
116
116
Lincoln, UK
Bailey 79-4T
Feb 2023
Whats the water level on the tank? Have you checked your water level cut offs? Are you hooked up to the mains?
Jul 15, 2023
116
116
Lincoln, UK
Bailey 79-4T
Feb 2023
Are these any good?
