- Apr 27, 2018
- 24
- 37
This is all a bit moot as the OP asked the question in Mar 2022.Ok, thanks for the replies, looks like I'll have to find a way to disable the split charge relay.
However I concur, you do need to disable the split charge relay action but that doesn't mean having to modify the NE237. I added a normally closed contactor with a low voltage schottky diode (an ideal diode would have been better possibly) across the terminals. When the engine is running the contactor operates and breaks the circuit. The diode across the contacts is reverse biased and so blocks any charge from the alternator. If the engine is switched off the contactor closes again and connects the habs battery to the engine battery via the NE237. It's necessary to retain the normal engine battery/alternator connection to the NE237 due to the way the fridge is wired. Other electroblocks have a separate connection for the fridge circuit but the NE237 has all the switching and wiring internal, fed from the main battery/alternator feed.
During my modifications (lockdown 2020) I also installed a Sterling inverter/charger and a 100Ah KS Energy Lithium battery. I separated the mains feeds inside the consumer unit so the fridge and truma heater are not connected to the Sterling output. The result is that if I turn the inverter on it feeds mains to all the 230V sockets in the van but not the fridge and truma. As the Sterling has an EHU changeover switch it automatically switches the sockets to EHU power if present. As the Sterling also charges the habs battery (and vehicle battery if you add the extra module) I removed fuse F7 from the NE237 to disconnect the internal charger. The lithium habs battery is charged by the Sterling at around 45A. The Sterling has the correct Lithium charging profile whereas the NE237 does not support Lithium. Having designed Lithium battery chargers professionally I caution against just selecting Gel or AGM of whatever. It will likely charge the battery if the volts are high enough but you rely heavily on the BMS inside the battery to protect against overcharging.
The Victron B2B charges at 30A maximum which means in practice the battery is 80% charged in less than a hour after a typical, off grid, overnight stop. In the summer months (when we mainly use it) the whole system is kept pretty much charged by the 230W of solar power on the roof. A friend has installed a 200Ah battery system in his van with some 430W of solar and he can pretty much run his fridge during daylight hours from the solar alone. I use gas for my fridge when parked up. I may add extra solar at some point.
All of my modifications are very easy to remove when I sell the van. I picked the Sterling unit over a Victron as the Sterling unit was the only one I could find that would physically fit in the electrics area. I also have a Victron MPPT charger as well as their B2B. It all works very well, I was even complimented on the quality of the installation by the Adria dealer's engineers! The van is an Adria Matrix 670SC for the record.
Hope this is of interest/use to someone!
