funflair
That should be what is going into your habitation batteries then, I assume you are on Lithium? we have a Lade-Booster 90A in the electrics locker and there are dip switches for settings, ours will only go down to 70A I think.Thanks Martin, so where are the dip switches you were mentioning? I am quoting the current on the Buttner monitor which shows 40amps when the engine is running. If you could tell me the location of the dip switches it may be a case they have been set at the lower current.
If you have one it may well be 24v-12v and they are only available 25A or 45A so you might have the 45A version (assuming that is output at 12v).
