Looks like it is back to school for me.
No is the answer to both.Thanks for the explanations on how surplus alternator capacity is used to optimally charge the cab and leisure batteries. Now, with the engine off and EHU does the B2B work "in reverse" to maintain both batteries?
With the engine off, and no EHU, but a solar panel fitted does the same logic apply? Which battery gets priority?
No is the answer to both.I think this is because the B2B doesn't sense sufficient difference between the voltages of the cab and leisure batteries.
Have you seen Charles Stirling on You Tube?
The Votronic 1212-45 is the same but if it has been wired through a separation relay or EBL it becomes isolated and will not be able to trickle charge. In other words it needs a direct connection to both engine and leisure batteries for this function, a Battery Master would overcome the problem.My Votronic 1212-30 (and possibly other Votronic B2Bs although I have no knowledge of them) supplies a trickle charge to the vehicle battery from the leisure batteries
Alan
My Autotrail is exactly the same and I'm not sure what to do for the best. When I trace the wires back to the Sargent PSU each of the separate battery leads plugs in separately. I suppose I could join the 2 together at the PSU side and run a new cables down to the batteries and parallel them up in the normal way, that would be easy for me as the the batteries and PSU are reasonably close to one and other.
Another thing for me is the split charging is built in the sargent |PSU and Sargent advised me this week that the Vehicle battery link into the PSU would need to be broken by a relay when the engine is running or else the whole thing will get it knickers in a twist.
Nothing is simple,is it?
These videos are good, but I wouldn't say excellent. He talks about a '100 to 200 amp battery', as if he wanted the charging current to be 100 to 200 amps.Excellent videos
Charles Sterling demonstrates that the old 'chalk and talk'(now whiteboard and marker) method by an well-qualified engineer can be as effective as highly-produced graphics and videos.
The recommended charging current for a 100 to 200 amp-hour lead-acid battery bank is C/5, which is 20 to 40 amps.
My take on it Dane, is in conditions when the alternator is feeding the headlights, heated mirrors, heater fans, air con, etc, and maybe not able to give enough charge to the leisure batteries, that's when the B2B comes into it's own, as it boosts whatever it is getting, to 60A, in the case of the unit I would want to fit.Another thing I don't understand with all this is, with decent sized wiring and heavy duty split charge relay the alternator will be putting out far more amps directly to the batteries then then say a 30 amp B2B charger will be. What am I missing?
A B2B is necessary if you got a new style smart alternator, usually euro6 up for diesel on vans. Also if you charge different chemistries: I.e. starter lead/ house Lithium.
otherwise old alternators work well with split charge on lead.
Not all. Mercedes based motorhomes have been using smart alternators for a few years now. Fiat were disabling theirs but now that they are no longer allowed to cheat the emissions figures I suspect the new ones will be active.My understanding is that smart charging/regenerative braking is disabled for motorhomes,
A B2B will keep the charging voltage matched to the needs of the leisure battery, including the bulk, absorption and float stages.Another thing I don't understand with all this is, with decent sized wiring and heavy duty split charge relay the alternator will be putting out far more amps directly to the batteries then then say a 30 amp B2B charger will be. What am I missing?
Use D+ the B2B will only activate when the alternator is charging
That’s what we didUse D+ the B2B will only activate when the alternator is charging.
You are not missing anything.Another thing I don't understand with all this is, with decent sized wiring and heavy duty split charge relay the alternator will be putting out far more amps directly to the batteries then then say a 30 amp B2B charger will be. What am I missing?
I only have a 30A B2B, but monitoring it with my BMV, it puts out around three times the current that the original split-charge relay on my van could manage.A B2B is necessary if you got a new style smart alternator, usually euro6 up for diesel on vans. Also if you charge different chemistries: I.e. starter lead/ house Lithium.
Same batteries but new wiring. Converter connected the split charge relay to the main power cable in the bodybuilders socket, which runs half way round the cab to the vehicle battery. I wired the B2B direct to the hab and vehicle batteries with heavier cable and a run about a third of the distance.Same battery and same wiring? If yes then your B2B outputs a higher voltage than the alternator can manage.
I dad a Durite in the past on the work van, changed it for a victron cyrix.
It's only a comparison in as much as I suspect many converter provided split charge relays are similarly installed such that ease of installation and cost are prioritised over performance.Then is NOT a even comparison. Since ohms law tells us that the current will follow to the least resistance path, your new improved conductors have contributed to better current flow and better power transfer. The old wiring could of been the bottle neck, or simply to much of voltage drop reaching the battery.
You can only push more amps by overcoming the internal resistance with raising the voltage. Hence why for a optimum charge the voltage drop is critical.
