Was looking to change the bulb in my outside light on the side of van,I presumed it would just be a bulb but found this ?Seems a bit Ott or am I missing something?
I agree. If the outer shell doesn't care about what the bulb is underneath, I'd look at ripping out the board so I'm just left with a 12v and ground wire. Then hooking up an LED. You'll get more light for less battery used.Florescent tube with an inverter to drive it, they had them on the Arc.
You can get LED replacements for the standard strip lights but not for that one.
You would be better to fit a complete new unit.
That’s what I did with internal fittings, just stuck led strip to base of unitI agree. If the outer shell doesn't care about what the bulb is underneath, I'd look at ripping out the board so I'm just left with a 12v and ground wire. Then hooking up an LED. You'll get more light for less battery used.
Me too, in principle. Actually I left the original in place, fitted new led beside it & just moved the power supply leads over.That’s what I did with internal fittings, just stuck led strip to base of unit
