Awning heater - any reccomendations for winter use?
Bailey Alliance 66-2
Any reccomendations (aware I can search but also looks to be some nice ones from Outdoor revolution).?
We have a full driveaway awning, and we wish to have a heater to use it (partially) over winter. We have an external socket, and any camping will be done with EHU this winter as we doing a Griswolds like Christmas and parking on a friends drive over New Years.
However, for the period before/after the stay on a drive, we are requiring our awning to have a little heat to expand the living space this winter and have a boot room as we plan some walks which will almost certianally involve a fair bit of mud.
(We do not plan to leave it on as some do all the time, this is merely to take the edge of the chill off and allow us to have keep the mud out this winter, we still have some mud on the carpets from LAST winter). (I have a job with a carpet cleaner to remove that this weekend).
Which dehumidifier do you use, our home one is WAY too big for use in the motorhome!
EcoAir I think it is. Has modes that you can program it to run at humidity levels, or clothes drying mode (flat out). Can also be plumbed direct to the drain.
We use one like this one.
Which spends most of it's life in our scullery at home drying all the laundry.
(We have never owned a tumble dryer)
It only comes in the motorhome on wet winter trips.
It has a carry handle on the top and a reservoir of about 3 liters.
The model will process 16 liters per day (if you were a tropical rain forest)
3 liters is enough to dry out all our laundry, it takes about 12hrs to fill up.
You can fit a foot of hose pipe to the drain, which then bypasses the reservoir, so that if it is put inside the shower, it will run indefinitely.
It's the size of a small 'carry on' cabin bag.
I would never consider trying to heat an awning to be honest. BUT if I were forced to I would use one of those all in one chinese diesel heaters. Parked outside and with the output vent under the skirt would heat the awning very rapidly and very cheaply using red diesel.
During that period, will you be on EHU or off grid?
If off grid, we've been using one of these for many years, initially connected to a gas cylinder, but now to a gas BBQ point.
If on EHU, a fan heater or halogen heater may suit your needs pending output and consumption per hour.
HTH,
Jock. :(
Used to do toast on that gas contraption on a toasting fork.
Marvelous!
We used these on building sites in the winter you can get smaller ones but I can guarantee you won’t be cold
Nor will they be with the much smaller and compact, but equally efficient gas heater I linked to earlier. 🤷‍♂️
Our huge caravan awning, as well as our MH pop up awning was/is snugly warm within seconds of ignition, and has been successfully so for years of autumn/winter camping. ;)
Cheers,
Jock. :)
Cheers,
Jock. :)
As I recall from our caravanning days, we used to also have a
Portable gas heater which ran from a cartridge system, similar to the portable camping stoves, and a quick Google for "portable camping gas heaters" brings in some interesting modern products.
Not sure if they are any good for toasting though.
Worth a look.
Hi!
Why don't you look at a wood burner? I have one fitted in my van from Little Burners, I remember seeing a post that they had a burner fitted in a bell tent (i can't remember where though, maybe Ireland?) so I guess it would be the same for an awning?
Otherwise, maybe a small fan heater, I've found the oil ones to not be very good at all though, but the blow air ones are good.
Hey don't forget if you if you mean an enclosed awning with skirt etc, make sure your not enclosing your fridge exhaust vent.
My Bessaccar E745 fridge vent was situated inside our awning, luckily the fridge flue needed cleaning else we would never have smelt the odourless carbon monoxide build up.
