Autowatch 695 alarm issue
Eldiss Majestic 155
I have an 2013 Eldiss Majestic 155 motorhome. Just recently the alarm is triggering after a few minutes of setting the alarm. Have previously checked and replaced the bonnet switch. If I disable the internal sensors, via the keyfob, the alarm does not go off. I have replaced the batteries in the habition area PIR and that has not sorted it.
Any other suggestions?
Rochester
Auto-Trail Mohawk
17 fun filled years
Does it do it if you lock the doors by the button on the dash? As the PIR's should be disabled.
Two on Tour
Elddis Autoquest 175
Do you have wireless contacts on any of your external locker doors or hab door?
Lincs
Our issue (different alarm) was a window sensor/switch, we took batteries out of each sensor till we found the culprit. The switch was fine but the fitting needed repositioning.
