autosleeper mercedes winchcombe questions (2 Viewers)
Aug 17, 2012
543
586
Burton on Trent
Autosleeper Winchcom
tenting,caravans,autotrail cheyenne,bolero, apache. and now Mercedes Autosleeper winchcombe
i have just bought a winchcombe as it fits our needs nicely but i have a couple of niggles, made worse by the fact its off to italy in a couple of weeks time.
Because i am an old git like most of us here im having to joust with the dvla about my " medical condition " and as a result my wife has got to drive, and as i do all the driving ( she likes to look out the window - and i like to drive ) she hasnt driven any motorhome for a few years and that prompted us to rush out and buy an auto, and i have alway fancied a Merc, and so.. NOW - the van drove nicely until she took the helm and booted it out of the services on the m5 and it stayed in second gear until almost 5000 rpm and which point i said pull over and lets see whats happening. we returned it to park and turned off the engine. We then started off again more gently and it worked fine. and she drove the remaining150 miles ok. Your thoughts gentleman ?
Also - it was 30c and after an hour or so we noticed the aircon that started off as a stronge breeze reduced to a gentle breeze and we proceeded to gently cook - thoughts ?
Finally for now... i will need the eu adapters 3 - i think - but when i looked online it asked did i want 1mm or 22 mm - is this the diameter of the nozzle on my van ?
Jul 18, 2009
11,269
18,178
HYMER B644
Is it a torque converter or Robotised manual (SprintShift)
Or just tell me the model year ?
roadwarrior
Aug 17, 2012
543
586
Burton on Trent
2016 and guessing 5 speed with toque converter, and lpg eu adapters
Derbyshire wanderer
1,304
2,417
Derbyshire
15 years
It is a 7 speed box and when it stuck in second gear the lever would have been knocked over to manual and locked in. Try on the next run and just knock it back to full auto for normal service. I did the same shuffling on the seat and knocked it with my knee.
The air con sounds like it may be ready for a regas top up. As it works for a while it is probably in good order but low on gas.
LPG adapters can be found on Amazon or caravan shops.
roadwarrior
Aug 17, 2012
543
586
Burton on Trent
thank you for that - but to be clear how do you put it in or out of manual or auto ? i see nothing on the stick to show that .
golly
2,007
69,848
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Doies the shift look anything like this
If so nudging the lever to left drops one gear each time it is nudged.
Aug 26, 2008
4,782
25,204
B&NES
since 2007
The ECU that governs the autobox adapts to the driving pattern, so if you boot it in 1st and keep the foot down on the loud pedal, it assumes you want max power and revs in 2nd, so doesn't change up sooner? Just my 2d worth.
May 12, 2011
1,193
1,872
West Midlands
Hymer
As golly has shown, if there is a + - on the control, it is dead easy to knock it out of automatic, the display on the sprinter will change fron D to whatever gear you lock into. Occasionally happens to me after years of driving an auto sprinter.
DuxDeluxe
14,672
73,110
Planet Zog
A woosh bang van
Side to side and look in the display for what is happening. I have made that mistake myself as well. Mercedes engine and 7 speed auto - great combination. Got the same on my bus (albeit with the V6 3 litre lump)
Apr 3, 2018
3,722
10,348
1995-2004 & 2017》
Don't know this particular gearbox.... roadwarrior However if she "booted it" as you say. Is it at all possible she inadvertently "kicked down" the box and if she then kept foot to the floor the box would stay in that gear until she eased off on the throttle... Just a thought.
roadwarrior
Aug 17, 2012
543
586
Burton on Trent
i think your all right gents - at least i know the gearbox isnt buggered now - thank you all for the enlightment - damn though - i watched it run to about 4700 revs befire i told to her kill it and pull over - jeez..
soo.. knock it left and it drops a gear - and to the right and it holds it in that gear ?
