Wow can't fault your tenacity well done would get my 10 quid
Deffo very informative and something that i would not even attempt , guess my Balls are just not that bigFor anyone who might still be wondering how to do this on the Uconnect 5.0 (VP2) radios, I've solved it, but it's not easy!
The radio off delay is a configurable setting in the body computer. 0 minutes (switch off with the ignition) is an always available option, so you can't remove that from the radio menu, but the delay time is configurable as 20, 60 or 180 minutes.
However, it would seem from previous postings here and elsewhere that Fiat dealers are either unwilling or unable to change this setting. It may be that the option is not available in the dealer diagnostic software. It isn't possible in MultiEcuScan either, but it can be done through a useful little app called AlfaOBD, available for Android and Windows PC.
You need the registered version to be able to make programming adjustments. The Android app costs £31 through Google Play Store and is automatically activated to the download device by purchase.
You will also need a compatible OBD adaptor (Bluetooth or WiFi for the Android app, I think the PC version can also use USB connections).
After selecting Fiat Pro as the make, then your particular version of the Ducato, connect to the Body Computer. The programming option allows selection of a Car Configuration Change procedure. Amongst the options is Switch-off Time, which can be set to 20, 60 or 180 minutes as above. Once the programming has completed, you need to carry out a Proxi Alignment procedure to ensure that the configuration change is notified to the network nodes on the vehicle. However, this is somewhat difficult with the Android app as you need a different connector cable for the OBD adaptor to be able to connect to some of the nodes that the Proxi Alignment procedure needs to write to, so I found it easiest to switch back to MultiEcuScan to complete the process. After the Proxi Alignment has completed, switch off the ignition, remove the key and shut all doors for at least 1 minute - job done
I was also able to clear two persistent trouble codes on my van, related to non-existent rear speakers. Because the van was factory configured with a connection at the conversion socket for rear speakers, the Telematics ECU has always complained of L&R rear speaker wiring faults as none are actually fitted. I was able to also change the Acoustic Configuration and Speaker Configuration settings in the BCU from 6 to 4 speaker cab - no more trouble codes and everything is working as it should
AlfaOBD also appears to allow programming of Peugeot Boxer and Citroen Relay ECUs, although not having either of those vans I can't try it.
One warning about AlfaOBD though: It allows you to attempt to program a lot of settings which may not be applicable to your vehicle, so you really need to know the default configuration before you start or you could find yourself in a lot of trouble. It would be better if it only showed the settings that are present for the ECU it is currently connected to, in my opinion.
The FM/As + 2 fix worked for me. However, I found that it only works if the ignition is switched on. 2013 Boxer.
This thread is older than your van.My peugeot boxer 2019 has zero or 180 mins can either be changed, at the moment i have it set on zero when the ignition is turned off the radio goes off, I just turn the radio back on without the ignition on, then try to remember to turn it off lol...
