They're not that quickI don't know if the roadster is better but my memories of smart cars are 5 second gear changes!
Are you sure you can beat a ZF or don’t you bother with the clutchWhat gearbox? Comformtic or proper torque converter one? The only flappy paddle/auto gearbox I think I would want would be a double clutch one like on Audi/Lamborghini. They are the only ones with decent quick changes like you can do on manual. Nothing like that available on motorhomes sadly.
Me too. The auto works perfectly almost all of the time, then for steep downhills I use the paddles and let the extra engine braking come into play.I have full control if I want it. I can shift gears with paddles. So I get the best of both worlds
Are you sure you can beat a ZF or don’t you bother with the clutch![]()
BMW car or bike platform? I am not aware they make vans?OK, add the ZF in too. When motorhomers start building on a BMW platform with a ZF gearbox I'll get a auto.
Actually the ZF is considered to be slower than the DSG in terms of gear changes but is more fuel efficient and maybe smoother. When it comes down to it the DSG is a 'proper' clutch gearbox whereas the ZF is a slush box.
The DSG is lightning quick but the Ducato 9 speed is plenty quick enough for a motorhome and I find it quicker than the manual one I took for a test drive.OK, add the ZF in too. When motorhomers start building on a BMW platform with a ZF gearbox I'll get a auto.
OK, add the ZF in too. When motorhomers start building on a BMW platform with a ZF gearbox I'll get a auto.Or maybe the Ford 150 with a 5th wheel.
Well, the quickness and smoothness of a manual box mostly depends on the skill of the driver -as does fuel consumption.The DSG is lightning quick but the Ducato 9 speed is plenty quick enough for a motorhome and I find it quicker than the manual one I took for a test drive.
Why dont you remove the starter motor, and get a cranking handle? Great exercise?Well, the quickness and smoothness of a manual box mostly depends on the skill of the driver -as does fuel consumption.
Look, basically I like to keep doing stuff myself. I have manual garage doors to make me get out of the car and open them. My car has manual window winders - good exercise for the wrists! Actually I cycle most places - into town, supermarket shopping. Trying to keep moving and active - including my left leg and arm. It also keeps the brain active. Less likely hood of falling asleep than in your comfy, smooth autobox car.
The IVECO daily uses the ZF 8HPOK, add the ZF in too. When motorhomers start building on a BMW platform with a ZF gearbox I'll get a auto.Or maybe the Ford 150 with a 5th wheel.
Auto but we have manual (Fiat) due to the crazy increase in cost of an auto
The dealer said that they produce fewer autos and they are in high demand therefore the price reflects that (no idea if this is correct or not)
It would be interesting if those who are adamant that they wouldn’t consider a modern auto in a moho would say if they have actually driven one - especially the current ZF 9 in the Ducato.
You can tell a manual box driver is behind the wheel of an auto, they live on the brake pedal. I've only been allowed to drive auto's for 27 years now due to a bike accident when I was 29. Driving auto requires different techniques.Reading through the posts from the diehard manual fans since my last, it appears that not many have actually driven a Ducato with the ZF 9HP in it then! Colour me unsurprised.![]()
On long motorway type journeys it doesn't make much difference …….
We have the 8 speed ZF in an IVECO daily and I would say that yes the top two gears are higher than our previous 6 speed manual.I’m sure I read it somewhere on the forum that the top 3 ratios in the ZF are all higher than 6th in the manual box, effectively overdrives, so possibly can have an influence on economy etc.
