Yes that what saidBetter sell my cars then as they all have them..
BUT,,, Maybe he's thinkin about the screen being on while driving forward ?? Did you ask for that ??
I assume he’s busy enough…
No he as done a lot of work for me But works buy the BOOKI assume he’s busy enough…
Cathode ray tube?? For those that don't know, it's the old-style TV/Monitor screen that was a deep glass bottle full of a vacuum (if you see what I mean). It had a triple electron gun that fired electrons (cathode rays) at the back of the screen through a fine mesh of holes. The modern 'Flat Screen' is not a Cathode Ray Tube, it is a backlit liquid crystal or LED screen. So no problem there.(2) In this regulation “television receiving apparatus” means any cathode ray tube carried on a vehicle and on which there can be displayed an image derived from a television broadcast, a recording or a camera or computer.
That looks like a very clever system designed to give full coverage, not just a simple reversing camera stuck on the back.Well I’m in big trouble then I’ve had Omni-View fitted which gives 360vision including ‘birds eye‘ view whilst driving
Great system ,costly ,but gives all round vision ,selectable view ie further back when reversing , constant 360 cam recording and the ability to use as 360 security cameras linked to remote monitoringThat looks like a very clever system designed to give full coverage, not just a simple reversing camera stuck on the back.
Same here and it works well.I have seen quite a few systems that are designed to only work when reverse gear engaged?
Never thought before if this was due to some regulation?
Mine is wired to be screen ON whenever I want it on and it shall remain that way!
Mine is the same.Our van has two cameras on the back, one for reversing which is selected when engaging reverse gear, and one to show a "road view" the screen is where the mirror would be and comes on as soon as the ignition is turned on, what's more is that this is all standard equipment supplied with the van, a 2022 British built van!
Very much doubt its illegal.
Even more to go wrong then. It’s getting too sophisticatedNext time you're on the motorway have a good look at the lorries you pass. On the new ones you will see what looks like tiny wing mirrors instead of the full size ones. They are cameras with screens in the cab. No mirrors at all.
Yes, and you can see sod all out of them. Very narrow field of vision compared to the old two mirror system.Even more to go wrong then. It’s getting too sophisticated
I don’t understand the folded in bit. If you need the long arm to see behind you surely it should stay unfolded at all times.Driving a LHD with a long arm Ducato mirror is a recipe for disaster. Whilst in UK the mirror is folded in then observing the rear view camera which connects to my Android mobile wirelessly via the app.
Very cheap and easy to install. 12 volts and off you go.
Whilst on UK motorways the mirror is folded out but on A and B roads folded in. You will have a blind spot of course but in general you can see what queue of traffic you have generated behind you. I think my unofficial record is twenty due to nowhere to pull over.
The worse case scenario for LHD drivers is being alone hitting a diagonal approach leading on to a another road which has priority when you cant see anyone coming.
https://www.aliexpress.com/item/1005001699127509.html?spm=a2g0o.productlist.main.9.227d2cf8wF5GLg&algo_pvid=aa34fd87-cc58-4f86-8fd1-5793ade27c63&aem_p4p_detail=202307290040231790457203346000006065202&algo_exp_id=aa34fd87-cc58-4f86-8fd1-5793ade27c63-4&pdp_npi=3@dis!GBP!36.10!17.33!!!44.85!!@21038edf16906164233177196e8d9f!12000017202444559!sea!UK!705904359&curPageLogUid=mRZqe6w3dg0U&search_p4p_id=202307290040231790457203346000006065202_5
There are different sorts of rear view cameras. Yours is designed for reversing when going slowly, and seeing as wide a view as possible. You can get rear view cameras that have a similar rear view to a normal mirror.I leave my reversing camera on when driving but it is no substitute for the mirrors. Firstly being on the back it leaves big blind spots where bikes and smaller cars can disappear. Secondly the wide angle lens distorts the perspective at the edges of the image. I can’t see why properly designed and positioned cameras should be a problem but reversing cameras can have their limitations.
Very true but I see a difference between cameras that are designed for rear view use and ones designed for reversing.It used to be that they would only be on when in reverse however technology has moved on and vehicles are now fitted with cameras and not mirrors .many also have in addition to mirrors cameras that turn on if the vehicle indicates to turn left showing mirror blindspotbut the screen is blank when not required. Many of the new vehicles that have cameras fitted have the screens in a similar position visually to where you would look in mirrors.
As technology moves on so does advice
My car has a reversing beeper as standard. Hybrid so silent at low speeds.I’ve got a reversing beeper… god I’m such a rebel….
