Attempting motorhome theft (1 Viewer)
Aug 22, 2007
2,796
36,896
essex
2017 sunlight t69s euro6
since 1999
A couple of xxxxxx tried to steal my motorhome last night but failed I have no idea how they got in no alarm went off and no sign of a forced entry only damage is the ns door panel
May 2, 2023
939
3,379
Kent, UK
Auto-Trail Frontier
I'm a newbie
OH is a mechanic and said from the pics, if you had your door secured with the locking cable and that attached to something, looks like they have unlocked the door and pulled it open breaking the door panel off with the force which is common apparently 🤔
OldAgeTravellers
1,456
2,498
Telford, UK
Since 1970
Sorry to hear this, looks like you had a cable between the doors and they have popped the lock and renched the door.
May I suggest that you now fit secondary deadbolts on all doors. The original locks are useless. I would also suggest checking the alarm by opening the doors, it is obviously using the built-in interior light switches which may not operate early enough.
Also a lesson for anybody else who chains their doors it needs an eye bolt screwed into the door as the pull handle which is attached to the trim is not strong enough.
pagey
Aug 22, 2007
2,796
36,896
essex
since 1999
yes both front doors are cabled to each other and both front seats turned and padlocked to the swivel bases
Sep 3, 2012
8,001
27,388
Cheshire
C Class Elddis 175
8+ years
Shame about the damage but that can be replaced unlike your motorhome that would have been taken without the bike locks in placethere doesn't appear to be any damage to the door locks to enable them getting into the van.
Were the bike locks and swivelled seats visible or were your side screens up.
Ps can you advise where this was?
pagey
Aug 22, 2007
2,796
36,896
essex
since 1999
Shame about the damage but that can be replaced unlike your motorhome that would have been taken without the bike locks in place.
replacement ordered being delivered tomorrow
Feb 16, 2020
2,639
3,654
KT15.
Sunlight. T66. 2019.
Absolute beginners.
So sorry to hear this. The out come could have been a lot worse, there but for the grace, and all that.
Mike.
pagey
Aug 22, 2007
2,796
36,896
essex
since 1999
yes all visible no screens on van parked at home nr epping
Sep 3, 2012
8,001
27,388
Cheshire
C Class Elddis 175
8+ years
They must have looked inside and seen the bike locks with the seats swivelled.
Makes you wonder why they broke in. Probably thought they could snap the locks. We usually use a couple of luggage straps linked together around the door arms.
I suppose the alarm didn't trigger because the doors weren't opened enough.
I would add some other protection now. Just to be sure in case they come back.
May be as well to wrap some white tape or similar around the bike locks so they are more visible (y) without them you would have lost the van.
Or me I will try again
Files are too large
Can you do some stills from the cctv.?
MisterB
6,776
15,590
Essex
Adria 670 SLT
sorry to hear of your predicament, at least they didnt get away with anything. it help me sleep better knowing we have a Growler from Vanbitz and a very good immobiliser, BUT its the damage they cause getting in and the feeling of being vulnerable that be very upsetting.
Feb 16, 2020
2,639
3,654
KT15.
Absolute beginners.
Was access initially gained by jemmying the door open or was that to break the home fashioned door restraints?
If not, do you know how the initial entry was made ?
Idle curiosity mostly.
Mike.
Sep 3, 2012
8,001
27,388
Cheshire
C Class Elddis 175
8+ years
All finished now another door panel ÂŁ55 including delivery but a bit of a job to fit
A good job.I wouldn't be put off from using the cable locks again. At least you know they work and for ÂŁ55 and a couple of hrs refit it was worth it to keep hold of your van (y)
pagey
Aug 22, 2007
2,796
36,896
essex
since 1999
If not, do you know how the initial entry was made ?gained
Idle curiosity mostly. access
Mike.
there is no damage at all on any of the doors or windows no idea how access was gained but glad there's no damage
43,803
53,142
How do the scrotes open fiat's as transits. An all purpose key off flea bay?
Basically yes.
I believe its an electronic scanner which reads the lock codes and transmits the code opening the doors and cancelling the alarm.
Available on ebay for a few quid.
Theres always a scroat with the knowledge and can make easy money.
Feb 16, 2020
2,639
3,654
KT15.
Absolute beginners.
They must have a mechanical master key. Forced entry would be much easier via the hab door or a window, otherwise why pick on that route of entry🤷.
