Adrian140974
Hi, does anyone know if the connections are different between Flo Gas and Calor Gas propane bottles please? Thanks
ThanksCan they go upwards from the bottle up to a higher level then back down to the regulator so that oils don’t flow directly downhill to the regulator?
That is, like an upside down letter U
I would say no, because you want any oily residues to run back to the bottle to avoid clogging the regulator.Can they go upwards from the bottle up to a higher level then back down to the regulator so that oils don’t flow directly downhill to the regulator?
Thank you I will look into this. To be honest the cabinet on the 890 is not very big, I was surprised and it clearly states 11kg maxTo add to your thinking, the flogas website shows 10kg Gaslight bottles
These are much lighter than the steel Calor bottles, but are they user refillable with LPG? LPG is so much cheaper than calor.
Safefill do user refillable lightweight 11kg LPG gas bottles but you would need the check the height. Surely they will fit in an Adria Supersonic 890?
They also use industry standard POL fittings.
When did Calor stop doing 11kg bottles? They're still on the Calor Website and my Builder Merchant still had them last time I went in (Early December).Great thank you. I have 2 x 6kg calor propane but my new motorhome will take 2 x 11kg, which calor don't make!! Would prefer to have 22kg rather than 12kg but wanted to check I could connect them. Cheers
Calor have never done 11 kg bottles its a contental size.When did Calor stop doing 11kg bottles? They're still on the Calor Website and my Builder Merchant still had them last time I went in (Early December).
I agree with Lenny HB . I was told the residues will collect at the low point in the pipe and when the pipe is full they get pushed in the direction of the regulator by the gas flow. The filters allow the residue to settle in the bowl leaving room for the gas to flow above the oils.Can they go upwards from the bottle up to a higher level then back down to the regulator so that oils don’t flow directly downhill to the regulator?
Hi. I called them today and they don't do anymore, they did not say when they stopped.When did Calor stop doing 11kg bottles? They're still on the Calor Website and my Builder Merchant still had them last time I went in (Early December).
You want either the 6 or 13kg Propane bottles, thats the usual sizes that fit in a motorhome gas locker.Hi. I called them today and they don't do anymore, they did not say when they stopped.
Agreed but my European van won't take bigger than 11kg. I currently have 2 X 6kgYou want either the 6 or 13kg Propane bottles, thats the usual sizes that fit in a motorhome gas locker.
Propane Gas Bottles | Mobile Homes & Catering | Calor Shop
Calor's Propane Gas Bottles, available in many sizes. Perfect for heating, cooking, commercial catering & caravanning. Shop the range online today!shop.calor.co.uk
Great info thanks, I did think about a test fit, will be calling local supplier tomorrow. ThanksI would test fit the 11kg at a friendly Flo depot (they exist unlike Calor!) - We thought about doing 11kg but found on our Bailey locker the 11kg bottles upper flange protection didn't give enough room to allow easy removal of gas bottle. We know we can fit 11kg Gaslow as several Bailey owners have had it done (mentioned on here), but the flogas bottles didn't fit as well in our locker due to the higher protection at bottom at top of bottle. If you compare a gaslow to a Flo bottle you'll see what we mean! (Should also say with a Gaslow system we wouldn't be pulling bottles in and out so the tightness of fit is less of an issue).
We at moment have one Flo and one Calor 6kg bottle to allow us to deal with any "individual supplier" issues. TBH as I posted on here yesterday it appears locally at least the Calor shortage has "gone" this winter, as bottles are available locally at least for both trivally, and much as it pains me to say, a Calor refill at 6kg level is £4 cheaper at present.
No, No, No, the bulkhead regulator MUST be above the bottles.
We’ll get 2 x 11kg Flogas bottles then, personally I’d buy refillables.Agreed but my European van won't take bigger than 11kg. I currently have 2 X 6kg
Same. I often have one of each on board, depending on what I can find.Hi, does anyone know if the connections are different between Flo Gas and Calor Gas propane bottles please? Thanks
ThanksSame. I often have one of each on board, depending on what I can find.
Wierdly locally theres about a £10 difference between 6kg calor £28 and 11kg Flo at £38 on my last prices from the flogas distrbutor.All fitted and well happy. Got a refund on old calor 6kg bottles. 11kg Flogas was £4 more than a 6kg calor, no brainer
I'd caveat that Flo gas Gaslight type plastic bottles do have a different regulator to the old BP ones (which used a POL connector) to my understanding at least. Don't go thinking all Flo propane bottle types are same regulator as both the 13kg (leisure) bottles and the gaslights use the 27mm clip on regulator connection instead of a POL.Same. I often have one of each on board, depending on what I can find.
POL to clip on adapters are available.I'd caveat that Flo gas Gaslight type plastic bottles do have a different regulator to the old BP ones (which used a POL connector) to my understanding at least. Don't go thinking all Flo propane bottle types are same regulator as both the 13kg (leisure) bottles and the gaslights use the 27mm clip on regulator connection instead of a POL.
No they are the same .. Standard POL. LJ thread.Hi, does anyone know if the connections are different between Flo Gas and Calor Gas propane bottles please? Thanks
Calor do 13kg propane if you can squeeze them in! Spec is available at https://shop.calor.co.uk/13kg-propane-gas-bottle.htmlGreat thank you. I have 2 x 6kg calor propane but my new motorhome will take 2 x 11kg, which calor don't make!! Would prefer to have 22kg rather than 12kg but wanted to check I could connect them. Cheers
11kg max size to fit but thanksCalor do 13kg propane if you can squeeze them in! Spec is available at https://shop.calor.co.uk/13kg-propane-gas-bottle.html
They do, or at least did until recently. I have an 11kg cylinder in my garage at this moment (empty, sadly), having moved on to Gaslow refillables.Great thank you. I have 2 x 6kg calor propane but my new motorhome will take 2 x 11kg, which calor don't make!! Would prefer to have 22kg rather than 12kg but wanted to check I could connect them. Cheers
From memory a Calor 11kg is a liquid offtake cylinder used on Fork Trucks. Called an FLT cylinder.Calor have never done 11 kg bottles its a contental size.
Calor only do 12kg & 18kg in FLT’s… I can‘t find 11kg anywhere in their cylinders. https://www.calor.co.uk/gas-bottles/which-bottle-do-i-need/business-forklift-trucksFrom memory a Calor 11kg is a liquid offtake cylinder used on Fork Trucks. Called an FLT cylinder.
You are correct.... Brain fade kicked in again!Calor only do 12kg & 18kg in FLT’s… I can‘t find 11kg anywhere in their cylinders. https://www.calor.co.uk/gas-bottles/which-bottle-do-i-need/business-forklift-trucks
EXCEPT in Ireland! https://www.calorgas.ie/11kg-propane
