- Aug 19, 2020
- 128
- 94
- Coach built
- I'm a newbie
Looking to change our MH. We currently have an Autotrail Apache 700 with the Comfortmatic Gearbox. Looking to get a full Automatic . Are Fords really that bad ?
Sorry edited to 1,100.00, hope that was inc Vat.£11,000?
I think it’s about theft. It appears that a high percentage of motorhome thefts are on a Ford chassis.What security fears do you have?
I wonder if the new 8 speed auto has any connection with Ford's connection with VW for the new VW Transporter as my MAN TGE (VW Crafter in disguise) also has an 8 speed auto.Ford have just replaced the 6 speed auto with a new 8 speed. If you are looking at dealers stock it is likely to be the older 6 speed as the 8 speed autos are just starting to arrive.
A lot of the wet belt problems with the Ford transit were due to the recommended 10 years or 150k miles between belt changes. They also had 30,000 mile service intervals! This meant that the belt was running in highly contaminated oil which significantly shortened its lifespan. Also, it is critical to use the correct oil which some independent garages were not doing. Ford have reduced the service intervals and now recommend that the belt is changed at 6 years or 100k miles. They also had injector problems but I think this has been mostly resolved. I would be happy to own one but I would have the oil changed every year and change the timing belt at 5 years. A new timing belt will be expensive. Currently about £1600 at a Ford dealership.
Had our Ford since 2019. Find it a far nicer drive and more comfortable than other makes eg Fiat. It’s 170hp so more than enough power for overtaking, hills etc. It’s a manual and you do need to use the gearbox when it comes to hills but it copes easily. Serviced every 12 months with correct oil and filter.
Averages 30-32mpg weighed at 3800kgs. No issues since we bought it.
The Transit is still the most popular make of van sold in UK by a large margin.
There have been a number of vehicles affected by injector problems, some with multiple failures. Why, I dont know. The initial ‘problem’ was issued by Ford as due to injector tip corrosion affecting vehicles built by a certain date using a known batch of injectors. My reckoning is that those affected should have stopped but there are a number of users have had injectors replaced only for further injector problems arising again. What the ratio of vehicles with problems to those that don’t I don’t know but you are more likely to hear of the ones having problems.
Next on the list is the ‘wet’ timing belt which runs in engine oil. Originally to be replaced at ten years/150000 miles Ford have now recommended replacement at 6 years. Issue seems to arise from timing belt sitting in oil, potentially contaminated by either the wrong type of engine oil used or oil that is contaminated by diesel due to short journeys/failed regeneration attempts etc. Replacements is not cheap and seems to come in at £1200 to £1500ish depending on what is replaced etc. We didn’t expect that bill for another four years.
Overall I’m happy with the Ford we have. It’s serviced regularly with correct fluid/parts and I’ll get belt changed at six year point to be on the safe side as it’s cheaper than a replacement engine!
Would I get another Ford……based on my experience yes…….
Honda also have one in their 1.0L turbo engine used in the Civic.Did you know that some Pueugeot /Citroens engines are also wet belt designs ......
I understood that to be a seperate issue to the injector failure issue? I understood that to create a problem of actually removing the injector from the engine due to external corrosion...caused by the water ingress into the engine compartment but not in to the engine.I sold my Ford Benimar Tessoro around 4 months ago, it was a great van to drive. Only had it for a year and had no problems at all, it was a 2021. My neighbour on the other hand, bought the same model on a 19 plate around the same time. He had injector problems twice, the garage only changed one on the first failure. The second failure he had them all changed, also the wet belt changed. He showed me a video of how they were failing, water was pouring in the engine through the bottom windscreen seal onto the injectors.
I had a 2013 transit custom for work from new, did 150000 miles in it, only problem I had with it was the dpf valve.
Not all Transits have an electric hand brake.Does the new Transit also have an electric hand brake like the 2025 Crafter (TGE)?
As I said, water on the engine, causing corrosion on the injectors. He had the wet belt changed, as it worked out cheaper while they were changing injectors.I understood that to be a seperate issue to the injector failure issue? I understood that to create a problem of actually removing the injector from the engine due to external corrosion...caused by the water ingress into the engine compartment but not in to the engine.
Brian....I figured the thread would go this way.....people with vehicle issues are generally far more vociferous than those without.
I get you now (your post actually mentions water in the engine, if you have a look ^)As I said, water on the engine, causing corrosion on the injectors. He had the wet belt changed, as it worked out cheaper while they were changing injectors.
Yep those are the probable choices I'm looking at myself too, but current generation of Ford has the wet belt scare and current generation of Fiat has problems with preheaters so I dunno which is worse, both can get costly . For other qualities I like the Ford a lot better to drive and the height for living quarters is nice, but Fiat is generally considered better in terms of corrosion resistance and a little cheaper maintenance.The main problem is that for the majority of us our choice of base vehicle is Ford or Fiat.
Should have said engine bayI get you now (your post actually mentions water in the engine, if you have a look ^)
No throttle on many Diesel engines.Reliability:- the only things to fail are the brake servo vacuum pump (twice) - what happened to the pipe from the inlet manifold? Too simple?
Well every ford i have had have been easily got into without keys. Handy if forgetful bit not if you are likely to lose your pride and joy.What security fears do you have?
No issues insuring our 21 plate Ford.My main worry would be security issues.
Have read not on FB that some insurers are refusing to insure ford based motorhomes, may be an urban myth. They fords i have driven have all been great, didn't like the 'sticky out' indicators on older vans.
In my experience of running a 68 plate Transit Custom 130bhp automatic work van I can’t fault them.Looking to change our MH. We currently have an Autotrail Apache 700 with the Comfortmatic Gearbox. Looking to get a full Automatic . Are Fords really that bad ?
for some of us veedub lovers it was a sad day when the transporter is now a transit .we got a new t5 kombi in 2012 we just use it like a car its had all the common transporter faults only 65k on clock.i drive the motorhome a round like a loon somtimes .but i nurse that kombi about .RIP THE TRANSPORTERI wonder if the new 8 speed auto has any connection with Ford's connection with VW for the new VW Transporter as my MAN TGE (VW Crafter in disguise) also has an 8 speed auto.
'Go old enough and no problem mine has a chain.'
How old is old? I rescued Norbert today but I have no idea what I'm doing!
