- Aug 19, 2020
- 108
- 67
- Coach built
- I'm a newbie
Looking to change our MH. We currently have an Autotrail Apache 700 with the Comfortmatic Gearbox. Looking to get a full Automatic . Are Fords really that bad ?
Ford have just replaced the 6 speed auto with a new 8 speed. If you are looking at dealers stock it is likely to be the older 6 speed as the 8 speed autos are just starting to arrive.Looking to get a full Automatic
I see you have a Chausson S697.We have a 22 Transit, it is a very nice drive)
Its the Wet Belt system they used. Cambelt can disintegrate with the wrong oil in the engine. Also apparently its expensive to change the Cambelt compared to other manufacturers. I believe these have been modified now in the 2025 onward models...Looking to change our MH. We currently have an Autotrail Apache 700 with the Comfortmatic Gearbox. Looking to get a full Automatic . Are Fords really that bad ?
I've heard the new 2.2 engine is nicer. But it's still the same brittle ride and sit-up-and-beg driving position. The Tranny is more car like.Are you comparing it to the old 2.3 Ducato or the new 2.2 I can't fault the new one
I like the driving postion it suits my dodgy back.I've heard the new 2.2 engine is nicer. But it's still the same brittle ride and sit-up-and-beg driving position. The Tranny is more car like.
Yes. Our first van/moho. The interior set up that suits us, a one yr old van only being sold as the 81 yr old owner was retiring from driving so he was offered miserly values at dealers (here in France). He got a bit more from us than they'd offered, we got it for a good bit less than the price that the dealers would have sold it for...everyone happy.I see you have a Chausson S697.
Are you happy with it?
Looks like a great van.
Local Ford mechanic said a big problem is driving short distances only and/or idling a lot. Think last leg delivery vans etc. That will result in dpf issues which in turn result diesel diluting the oil and finally belt problems. An hour on the road at cruising speeds every 500km ensuring a proper dpf burn & regular oil changes was his recipe to avoid belt trouble. Also, always pre-heat if it's freezing.I also suspect another aspect of the issue with Ford Transit MoHos and their wet belt woes is that many are sat for weeks or months....then driven...then parked again for weeks or months. It is staggering how many seem to do less than 2k miles a year. This cannot help. (We have a 22 Transit, it is a very nice drive)
I think that was me GusSomeone recently posted a you tube video of a complete wet belt change from an independent that does them constantly with price & list of parts that are changed .I can't remember the price though but thought it was excellent considering the amount of parts needed +work.
here post #18
https://www.motorhomefun.co.uk/forum/threads/wet-belt-change-interval.307484/
£11,000?I think that was me Gus
Yes a very detailed video showing the full extent of the work that needed done to change wet cam belt on transits.
The price he said was competitive, which I guess would be if doing them often.
£11,000 was the take it or leave it price quoted, I guess Ford Dealers would be much more somehow.
LES
its the most popular as its mainly big companies that buy them in fleets as they like the price and the service deals they only keep them 3 years or so; a new transit is cheaper than a merc toyota ect....if merc ect were doing cheaper fleet deals ...now be intresting to see how these prices fleet deals pan out now the vw transporter is a transitHad our Ford since 2019. Find it a far nicer drive and more comfortable than other makes eg Fiat. It’s 170hp so more than enough power for overtaking, hills etc. It’s a manual and you do need to use the gearbox when it comes to hills but it copes easily. Serviced every 12 months with correct oil and filter.
Averages 30-32mpg weighed at 3800kgs. No issues since we bought it.
The Transit is still the most popular make of van sold in UK by a large margin.
There have been a number of vehicles affected by injector problems, some with multiple failures. Why, I dont know. The initial ‘problem’ was issued by Ford as due to injector tip corrosion affecting vehicles built by a certain date using a known batch of injectors. My reckoning is that those affected should have stopped but there are a number of users have had injectors replaced only for further injector problems arising again. What the ratio of vehicles with problems to those that don’t I don’t know but you are more likely to hear of the ones having problems.
Next on the list is the ‘wet’ timing belt which runs in engine oil. Originally to be replaced at ten years/150000 miles Ford have now recommended replacement at 6 years. Issue seems to arise from timing belt sitting in oil, potentially contaminated by either the wrong type of engine oil used or oil that is contaminated by diesel due to short journeys/failed regeneration attempts etc. Replacements is not cheap and seems to come in at £1200 to £1500ish depending on what is replaced etc. We didn’t expect that bill for another four years.
Overall I’m happy with the Ford we have. It’s serviced regularly with correct fluid/parts and I’ll get belt changed at six year point to be on the safe side as it’s cheaper than a replacement engine!
Would I get another Ford……based on my experience yes…….
