Tombola
1 -9 for a copy , golden bullet here in my long nosed henry, my 20 is going to be cruising the shores of blackpool and the north in the MH this next week
What about a rubber duck? Or a small loaded aerialI investigated CB before but drew a blank, the problem is the antenna I enquired at a few CB shops but all said the antenna had to be a certain size/ height which just doesn’t work on a already high A class.
we ended up with a couple of UV5R walkie talkies then up rated their small antenna they work well as hand heads with around 1/2 a mile normally but the terrain maters the best we have ever got is in a valley in Germany where we got around 3 miles.
My friend and I would like more range with something like a cab but I just can’t see how with out a big antenna looking a mess.
It was deliberately left out of the present legislation to avoid putting a lot of professional users in a compromised positionIs it legal to use a handheld mic whilst driving?
Ahem..............My current home base set up . Needs a good dustingView attachment 572043
If you mean the Baofeng uv5r they are illegal unless you have a amateur radio licence, they transmit on 2 metres & 70cms.I investigated CB before but drew a blank, the problem is the antenna I enquired at a few CB shops but all said the antenna had to be a certain size/ height which just doesn’t work on a already high A class.
Please see my post above to SwifterI investigated CB before but drew a blank, the problem is the antenna I enquired at a few CB shops but all said the antenna had to be a certain size/ height which just doesn’t work on a already high A class.
So as a paper weight to hold down you log !I only use the amp within my license guidelines.
ExactlySo as a paper weight to hold down you log !![]()
