Seen these advertised, does anyone use. Do you think they provide a benefit worthy of £250 outlay?
Dont laugh, its not soft furnishings for retired tyres, nor the spanish inquisition. They are also labelled "tyre savers", here is the link, came across it while explorering differnt security options:Do what?
Other versions are available on ebay and amazon at various price pointsTyre Protection Cushions - TYREDOX - set of 4 | Van Comfort
Tyredox are a full rubber cushion for motorhomes and prestige vehicles, designed to stop the damaging effects on tyres when in storagewww.vancomfort.co.uk
They are the price of 1.5 tyresSeen these advertised, does anyone use. Do you think they provide a benefit worthy of £250 outlay?
Don't see the point it still has the full weight of the van on it. Snake oil comes to mind.Dont laugh, its not soft furnishings for retired tyres, nor the spanish inquisition. They are also labelled "tyre savers", here is the link, came across it while explorering differnt security options:
Someone is buying them!Fiamma Wheel Tyre Saver Cradles Caravan Stops Flat Spots Pair Garage Parked | eBay
Fiamma Wheel Tyre Saver Cradles. Can be joined together for vehicles with wide wheels. Wide Range Selection. Size: 460mm (L) x 210mm (W) x 60mm (D). Colour: grey.www.google.com
Used these for 10 years. 5 to 6 months at a time never had ovulation.
I get 3 for that muchThey are the price of 1.5 tyres
Sounds like an great example of an expensive solution looking for a problem . . . .Seen these advertised, does anyone use. Do you think they provide a benefit worthy of £250 outlay?
One born every minute.I saw it called ovalisation.... do you suffer from ovalisation.....
and yes £250 for 4 molded rubber mats, seems excessive but they did mention specially designed!
many cant recognise sarcasm eitherOne born every minute.
Buy four axle stands and use your supplied jack.... They also have many other uses unlike the overpriced rubber mats.
You wouldn't. You're a bloke.Fiamma Wheel Tyre Saver Cradles Caravan Stops Flat Spots Pair Garage Parked | eBay
