Anyone knows where I can get hold of a seat lock? (1 Viewer)
May 29, 2020
301
375
Wiltshire
Westfalia Columbus
Since March 2024
With collection day looming fast, I'm looking for one of those small locks which locks the driver seat facing backwards. Halfords sells steering locks which would do the job but I prefer something much smaller to put away when not in use.
53,838
151,646
beachwomble
May 29, 2020
301
375
Wiltshire
Westfalia Columbus
Since March 2024
Thanks all for your answers. I was looking for a thread about it but couldn't find one.
Jun 30, 2022
355
2,179
burstner lyseo 590
We bought one of these…. It locks both seats (swivelled) together
pwilmo
349
546
Kings Lynn, Norfolk
Auto Roller 747
This will help, I think just what you are looking for
This may be handy info for if you are wanting to fit a Patriot lock.
The info is all out there already posted, but not all in one post.
Short shackle in the locked position : 10.5mm gap
Long shackle in the locked position : 45mm gap
Short shackle: 40.5mm length
Long shackle: 75mm length
Length of shackle inside locked body: 30mm
( same for both locks )
Longer shackle length may be a problem if you have a narrow space underneath the swivel base.)
Unfortunately on the driver seat of my Ducato Bessacarr 2006 the overall width of the two swivel plates was 14mm.
So I bought the extended shackle Patriot ( the one for use with a chain), and padded the shackle underneath with M14 x 30mm diameter washers to make a snug fit. Maybe for "On - Off" usability, gaffer tape around all the washers to form one large spacer piece.
The window stickers I designed and printed out on normal paper. I used clear wide parcel tape, sticky side onto the printed side, trimmed off accurately any excess parcel tape around the edges of the label shape.
Layed out a length of parcel tape, sticky side up.
Carefully positioned the label shape ( unprinted side down, printed side up ) onto the parcel tape, so that width of the tape overlap was equal along the top and the bottom edges. Cut the end tape overlaps to be a liitle wider. This was ready to stick to the inside of tbe windows.
View attachment 470421View attachment 470422View attachment 470423View attachment 470435View attachment 470424View attachment 470425View attachment 470426View attachment 470428
Jan 27, 2018
2,690
2,138
Northampton
Rapido & Bongone
Jul 29, 2022
520
915
Watford, Hertfordshire, UK
Swift Kon-Tiki 599 S
Personally I want a "security device" to be overt to deter, not covert and discovered after breaking in.
I have a millenco peddle lock but it is only visible after entry into van, so secondary defence.
Big yellow disc lock, anti harpooning plates (Ducato issue), T series deadlocks, habitation door overlock, are
externally visible deterrents.
Hoping thieves will target someone else van, not sorry, you can install the same.
Aug 19, 2007
717
1,081
Stockport
Tribute 615T sport
17 years + since 2006
Any chance of a description and/or pics of it in place? Where on the seat frame does it attach?
Mines on a ford transit, seats don't turn fully and didn't need to drill hole, bit fiddly to fit but good deterrent.
Feb 16, 2020
2,334
3,192
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Mines on a ford transit, seats don't turn fully and didn't need to drill hole, bit fiddly to fit but good deterrent. View attachment 878796
I would be tempted to take your vehicle to a quiet area, apply the lock and try for yourself to evaluate if it's possible to drive the van away, even if a bit uncomfortable. My suspicion would be yes, if a bit awkward.
Mike.
Reactions: Joc
May 16, 2015
114
208
Reading
Elddis Accordo 125
I use. Motorbike disc lock with the seat turned works perfect
Sep 19, 2018
93
111
Falmouth
Ducato PVC
3year
I use a good bike D lock that goes through an existing hole. Not as hard to grind off as the bike Patriot but I had one lying around..
May 26, 2016
1,350
4,397
north wales
low profile
moderate
A simple padlock placed beneath the seat - within the metal base of the seat - works just fine for me.
There should be a couple of convenient "holes" to thread then padlock through.
Jun 30, 2022
355
2,179
burstner lyseo 590
A pic of it in place would be good Go_buddy_go_
Sorry just looked at forum and Moho is back in storage so can’t post pic but it locates over the bars at the bottom of the seats [ the one’s you use to put the seats back and forward… if that makes sense? ]
Nov 16, 2021
13
16
Oundle, Peterborough, UK
Elddis CV60
I'm a newbie
Try this alarmed motorbike lock. Very robust but small, very easy to fit and you can drop it in the door pocket when not in use. You just have to drill a single hole in the seat base. https://www.amazon.co.uk/dp/B09FX27K6P/?tag=mhf04-21
Aug 19, 2007
717
1,081
Stockport
Tribute 615T sport
Mike.
yes you could and i have drove it out of the car park onto the road , but don't think you would get far with the seat turned ,
