anyone know what type of receiver this bung fits in
Cheshire
Lunar Home Car P59
I'm a newbie
I'm a bit surprised by the design of this water tank as the bung is really awkward to get to
It's only about 6" deep and as the drain plug us next to the cap I assume it's the same all over as this must be the low point
Anyway the plug leaks , a lot , not just a drip , almost a stream , I've tried warming it up in hot water to soften the rubber to push it in harder but it leaks just as much so I'm thinking whatever I'm pushing it in to is what's leaking
This is the style of plug but it's in such an awkward place you can't put it in straight and lock it
If the receiver is push in that would make it easy , I don't really fancy crawling about under the van if I can help it
take your clothes off, skin is waterproof
Could be a bit painful if his 'dangly bits' got scrubbed on the drive whilst placing and retrieving the bowl! :oops:
I wouldn't subject the neighbours to the horror of seeing me naked
The good news is it gone from drip drip drip to drip -------------drip------------drip so I think a bit of self amalgamating tape will seal it , I bought 2 bungs, sizes 22mm & 25mm , it's looking like it actually needs 23.455009934mm ,I think it's a water tank off the space shuttle
Try a cut down 'finger' from a rubber glove ...
I'm going to try plumbing PTFE thread seal tape , it’s so tight even the thickness of the rubber tape stops it pushing in easily, I can’t believe what a PITA this is being
good news I sealed the skylight so nothing coming in from above now
bad news , we’re on lockdown from Saturday so I can’t go anywhere in it , though the government advice is ambiguous , they’re discouraging all but essential travel and we can only use outside hospitality , so I can drive as it’s only discouraged , and outside hospitality , is that a camp site ?
who knows
Well thats it, I admit defeat , no matter what I try i can't stop it dripping , new plug, ptfe tape self amalgamating tape, next step seal it from underneath
A special mention goes to Minxy Girl , I do worry about where she got the idea , chemist shut , no 50p coins for the machine
a good effort but that didn't work either
View attachment 430142 a good effort but that didn't work either
Are you absolutely certain that the spigot on the tank hasn't split? It really shouldn't be that hard to seal.
The least leaking was with the new bung with no tape on it , it's a rubber seal that feels like a pressure fit as I can move it in the white plastic tank so it might be the oversize is distorting it making it leak, I can't feel or see any splits
It's going in for mot soon so while it's on the ramp I'll see if they can seal it from underneath
If you can get the tank dry, put some gaffer tape over the hole and see if that stops it, if so at least you then know it is definitely there where it is causing the problem and not a leak elsewhere.
Also, have you stuck your finger in the hole itself to see if there is something stuck to it thus preventing a proper seal, eg part of an old rubber seal?
As for your picture ... you don't get to see that every morning! :giggle:
It's on the ticket on the bag www.1stmark.co.uk
It's in golbourne near leigh , one of those places where there's 5 seconds thinking a rummage and it appears
Good news , straight through the MOT so no more covid test
Bad news tried fitting a bung into the water tank leak from underneath and made it worse
It can't be bodged, it needs taking out and doing properly
Thanks Wack only 10 minutes away so it’s handy to know 👍
No more leakage from the water tank , it'd been bodged spectacularly , its a simple enough thing , drop in from the top , rubber seal either side , big plastic nut , tighten until it doesn't leak , put bung in
Only the nut must've worked loose , instead of tightening it somebody thought it was a good idea to squirt a tube of sealant all around it , fabricate a plastic plate and screw it on to keep the sealant in
Once cleaned up and tightened properly no leaks
