If your HW45 is putting out 11.5 ft/lbs , I hope you have a firearms certificate as the legal limit in Britain for a pistol is only 6 ft/lbs.Its exceptionally clear what caused this damage and especially as I have taken the time out and actually fired a lead pellet into a similar surface and photographed the result that shows a clear defined image identical to the OP's posted pic. This was the damage from a 0.177mm 8.44grain pellet at around 750 ft/sec approx' 11.5 ft/lbs from a distance of 3 metres.
You are correct, my HW45 on full power only puts out max at 5.5ft/lbs, sorry for quoting my TX200If your HW45 is putting out 11.5 ft/lbs , I hope you have a firearms certificate as the legal limit in Britain for a pistol is only 6 ft/lbs.
From 10ft, yes..... But the pellet which caused the damage could have travelled 50mtr, 75mtrs, 100mtrs.....who knows.You are correct, my HW45 on full power only puts out max at 5.5ft/lbs, sorry for quoting my TX200. The actual test was made with my HW45. My TX200 would have probably gone straight through!!
I once popped a magpie @ 120yd with my legal Walther LG300 Dominator, was a very fluke shot as it was out of view in my scope.From 10ft, yes..... But the pellet which caused the damage could have travelled 50mtr, 75mtrs, 100mtrs.....who knows.
Who's to say it even came from a legal air gun.
I once got a rabbit at around that distance (edit... Rose tinted glasses maybe) with my old BSA Meteor.. Long before the mambies set a max spring power.I once popped a magpie @ 120yd with my legal Walther LG300 Dominator, was a very fluke shot as it was out of view in my scope.
A could of points here... You haven't fitted a pellet into a similar material at all... Your glass jar lid is steel and I'm assuming it has the rubber type backing to avoid contacting the food? Your comment pertaining to knowing the ammunition weight from one photo is complete nonsense you shoot a piece of metal which, suprise suprise, made a round dent, you are them composing this to another picture of a round dent and claiming this is the only possible answer. As regards to the range, are you then claiming that someone climbed over the OP's gate with an air rifle, walked to roughly the metres away, shot his motor home, the climbed back over the gate and walked away?? Sounds a bit far fetched to me.Its exceptionally clear what caused this damage and especially as I have taken the time out and actually fired a lead pellet into a similar surface and photographed the result that shows a clear defined image identical to the OP's posted pic. This was the damage from a 0.177mm 8.44grain pellet at around 750 ft/sec approx' 11.5 ft/lbs from a distance of 3 metres.
Only 35 years !A could of points here... You haven't fitted a pellet into a similar material at all... Your glass jar lid is steel and I'm assuming it has the rubber type backing to avoid contacting the food? Your comment pertaining to knowing the ammunition weight from one photo is complete nonsense you shoot a piece of metal which, suprise suprise, made a round dent, you are them composing this to another picture of a round dent and claiming this is the only possible answer. As regards to the range, are you then claiming that someone climbed over the OP's gate with an air rifle, walked to roughly the metres away, shot his motor home, the climbed back over the gate and walked away?? Sounds a bit far fetched to me.
Regarding my comments about the ammo etc, I've been an active shooter for over 35 years and am a fully qualified armourer.
See post 124.A could of points here... You haven't fitted a pellet into a similar material at all... Your glass jar lid is steel and I'm assuming it has the rubber type backing to avoid contacting the food? Your comment pertaining to knowing the ammunition weight from one photo is complete nonsense you shoot a piece of metal which, suprise suprise, made a round dent, you are them composing this to another picture of a round dent and claiming this is the only possible answer. As regards to the range, are you then claiming that someone climbed over the OP's gate with an air rifle, walked to roughly the metres away, shot his motor home, the climbed back over the gate and walked away?? Sounds a bit far fetched to me.
Indeed, and in only 35 years I've been a competitive youth sporting and skeet shooter, a shooting instructor for a number of clubs, a member of the Royal Navy full bore target rifle team, competing in both tri-service and national competitions in the 900 yard open sight discipline, a small arms maintainer onboard 1 RN frigate and two RN nuclear submarines as well as a fully qualified armourer. Absolutely terrible aren't IOnly 35 years !![]()
I have some EU ones that I use if it’s any help ?Put a sticker over it. Seems like GB stickers will be coming back into fashion any time soon.
