Yup, today was a real washout, wasn't it? Same for my optimally-tilted, South facing array on the garage roof. Going to have to buy a few kWh from Octopus tonight.
We had one on our last van. It worked extremely well but was expensive. Our Wi-Fi is poor we are in South America.IIRC Gaston aires has or had an Alden system which tilted the solar panels whilst tracking the sun (or similar)? It’s also possible I might be imagining such.
I had a solar panel that tilted and turned following the sun every 20 miy , I swear to turn it it took all the power that had been previously put into the batterySome of those tilting methods look a bit precarious and all adding extra weight
I guess that’s a joke, in reality a tilting actuator takes tiny energy, a tracker even less, the move is minuscule as is already up.I had a solar panel that tilted and turned following the sun every 20 miy , I swear to turn it it took all the power that had been previously put into the battery
It was a French system ,never was that efficient.I guess that’s a joke, in reality a tilting actuator takes tiny energy, a tracker even less, the move is minuscule as is already up.
In my case, it lifts in 50 sec say 1min, then another one for lowering, then twice a day, 2amp motor, at 13.6v, it’s about 1.8-2wh. Even if you multiply that by 10 to cover for a cumbersome inefficient tracking mechanism, that’s still only 18-20wh. My router eats that in a hr.
When it’s overcast, with diffused light and no sun, best orientation is straight up zero tilt. You will capture all the cloud diffused light with max surface exposed. In this particular situation, if you tilt, you reduce the panel area pointed to the sky, hence less harvest. It’s called albedo.One issue nobody's mentioned is that rainy or very cloudy days are when you really need every kWh of solar power you can get, and tilting doesn't help much here - the sky is pretty uniformly bright. Or dark. Ive had tilting panels on my garage roof for a couple of years and found that in the past 2 winters. Today I compared dead horizontal with 65 degree tilt (which is about optimum for Weymouth in December) - no significant difference (a tiny bit, but I think it got ever so slightly brighter at that point!). So, if you want power to run a fridge, lights, toaster, microwave, kettle, electric blanket and maybe a bit of electric heating, in winter, off-grid, there's no getting away from just having huge panels. Of course you may question why anyone who lives on wheels has to be in a place thats cold and cloudy for days on end ........
That was my conclusion. When the summer sun is out, you don't need much panel area. When it's dull and through the winter, you need a dozen times more area... I don't have enough roof!Tilting helps with keeping the panel cool as well, as it gets a breeze and no heat build up. Cold panel, high voltage. Win win. I agree with PV sizing, you can only go so large before becomes cumbersome. In winter large array only helps when the sun is out, but a combination of things will benefit to ride out of those dull days. Storage, I found a minimum 5 days storage it’s a workable compromise, more it’s even better but gets expensive, and in my case very addictive.
Interesting! I thought of going off-grid at home, to save the £180 a year standing charge, but the excess power I sell in Summer more than pays for it over a year, so Ive stayed on. But part of me wants to go off, just to stick it to them. I really resent this non-usage based charge. We have gas too, and in Spring and Autumn when heat is needed, I substitute gas usage (water heating, space heating, cooking) with electricity, rather than selling the power. Ive got the van plugged into the mains now, and with no load on it exports solar power back to the house. Tiny, but the big benefit of this is to show Mayya the little arrow in the green on the meter. It stops her reminding me how ridiculous our van looks with those huge panels on it. To be fair, she does have a point.It is hard indeed, oversize panels, and oversized storage, to a degree it will help to go trough couple of weeks of grim winter. I have personal experience with off grid living in our house, I had winters with no generator hrs at all, some with 4-6 hrs and some with almost every day for 4 hrs for 2-3 weeks.
Now as I switched to lithium for the house and doubled the initial PV, we use no generator, and manage to charge the car as well. In a grim winter, if the sun peaks for 2hrs, I have the storage and the panels to harvest as much as 16kwh in that space. The ability to grab fast as much as you can it’s the solution for the winter. At least works for me.
And that’s exactly what I replicated with the van, sun out? Gobble gobble,
