funflair
That is because your fridge doesn't have an S+ connection & Martin wired it to the D+ using a diode to isolate it from the alternator D+.
I have just ordered a single 320 AH from Eco Tree. I called up and they gave me a 10% discount code MHF21 so it was £1529.10 in total for 320 AH. The Kon Tiki battery box is 750 length by 300 wide by 280 high. The eco tree 320AH easily fits in here and is much lighter. Will report back when they are fitted at the weekend.
Most days we get 150w easily and in full sun we get 350-400w from the solar setup.
We got 470Wh in mid July's blazing sunshine from a 180w Solar Panel connected to a 120Ah Lithium Battery when off grid. We have had trouble using all the available power from the Lithium, so we've had quite a few days where 150-180Wh has been produced, with the rest of the day spent with the Battery in gentle Float or Absorption mode. I expect the Leisure Battery to work harder in the Scottish Autumn with Solar Panel [17:30] now sleeping and the need for lights, phone chargers etc starting much earlier in the eveningIs that watt hours or peak output? I'm asking as i'm still trying to understand exactly what i'm getting from my 300 watts of panels and Victron 100/20 on a nice sunny day i got 430Wh on cloudier days less, P max seems to be around 137W
I recommend Sterling , and are I believe the only ones covered for use on the road ( don't quote me on that,talk to vanbitz) I have 260 ah of sterling batteries and not had an problem at all.Are the Sterling lithium batteries any good? The BMS built in to those includes bluetooth to provide shunt/BMV type information.
Sorry don't agree, no way is a 16 hour absorbtion phase suitable for a Lithium battery.Totally depends on the charging parameters.... KS Energy batteries for instance are perfectly matched to Schaudt Elektroblocks ... i know van owners who have done this and have had no problems at all..
That's Fine...as i say i haven't done this but know owners who have and they are performing excellently with no issues at all.... having read the blurb on the KS website they even explain all the workings of doing exactly this...Sorry don't agree, no way is a 16 hour absorbtion phase suitable for a Lithium battery.
Sorry don't agree, you will never get the best out of them in performance or life if you don't charge them correctly.That's Fine...as i say i haven't done this but know owners who have and they are performing excellently with no issues at all.... having read the blurb on the KS website they even explain all the workings of doing exactly this...
Our "Super Series" lithium leisure batteries are genuinely smart and incorporate Bluetooth and low temperature charge protection as standard.
Our batteries have been designed to be a like for like no-nonsense drop in replacement for older AGM, GEL or lead-acid deep cycle leisure batteries. There is no requirement for you to change or modify your existing mains or solar chargers and our batteries can be charged directly from the vehicles existing standard fixed voltage 14.4V alternator. They "abuse proof" in that they incorporate over charge/under charge/over temperature and under temperature protection.
But don't forget these are working in tandem with a Lithium set Solar MPPT controller.... yes it wont be at optimum charge but with solar and possibly a B2B as well it covers pretty much all bases.... and if the on board charger is not charging to full capacity that if anything is a good thing in my opinion as keeping Lithiums at full charge is not a good thing.. finally these batteries from KS carry a 7 yr guarantee... so if anything dire should occur you are covered..Sorry don't agree, you will never get the best out of them in performance or life if you don't charge them correctly.
Drop in replacement is salesman BS IMO.
hey up ! dont get your knickers twisted on such a lovely day , its only advice and good advice too.And how can it be "salesman bullshit".. when they are covered by a guarantee and its all in their technical instructions ... if you are following the "bullshit" as you call it and a failure should occur then they will have to replace them... unless of course you think the guarantee is bullshit too.... in which case they wont be in business long will they..
