That’s what we did last year, but one of us got anxious about it, so this year we put them on! Certainly there are a lot more with them this year than last - even some French vans!I bought them but didn't stick them on. If questioned I'd have got them out but seems nobody is really bothered, least of all french motorhomers.
But I avoided any major cities, maybe different there ?
Angles Morts
Do you have to have them on your Motorhome when travelling in Europe.
Regards Martin
It would still be your fault. Stickers or no stickers. If you had the stickers then it might reduce your prison sentence slightly.Not necessary until…some fool cycles up your inside in a blind spot and you inadvertently turn into them and knock them off. Gendarmes arrive, ‘ how could the cyclist possibly know it was dangerous to cycle up the inside as you didn’t have warning stickers to tell them? Come with us to the guillotine’
you stick them on,before assisting the half wit,& before the gendarmes arrive.some fool cycles up your inside in a blind spot and you inadvertently turn into them and knock them off.
See a large German 4x4 towing a massive Adria caravan when on a site in Croatia, probably 14-15m long all in and with normal car mirrors on I cannot see how he had good visibility!!Ever since the French published the requirements for these 'Angles Morts' I have failed to see why the danger areas indicated by '!' marks are in the yellow areas to the sides of the vehicle.
The vehicle cannot move sideways into these areas, but the danger to cyclists is in the black areas where they can get trapped when the vehicle is turning a corner.
The only way a cyclist or other vehicle can be in danger from the side areas is if they drive straight into the vehicle.
The other illogicality is that the requirement to display is based on weight not length, so for MHs the same dimension vehicle can be under or over 3.5t and need or not need the stickers.
I am not surprised many French are ignoring the rules.
Hi Bessy, it's on my list to buy some of these before we head across the Channel in the New Year. I'm just trying to decide whether to go for the suction cup version from Reflecto online. Did you find they stayed on ok please? Did you remove them when you were parked up? Thanks in advance.
