Kannon Fodda
- Feb 26, 2019
- 2,636
- 8,118
- Autotrail V-line 540
- I Make Schoolboy Errors!
What am I missing?
How do you push the crimped wire end into the plastic fitting. It just will not go in.
Blade is the right way i.e bend end faces down if the plug bit is also down. But i can't put any pressure on to push and lock. Im going to end up stabbing myself trying to get a screwdriver edge on the edge of a crimp
Watched loads of you tube stuff and it all seems so easy with nobody needing anything other than a crimp tool and wire stripper
