Ampere Hours Ah
Carpmart the back is completely flat and goes back against the wall unlike the old fridge you will have to remove the seal used to separate the gas part of the old fridge as it will stop you pushing it right back to the wall.
Seals already out Steve… 230 socket removed also… and yes, it looks cleaner and tidier than when I took the picture! 😇
just got cabling and pipes at the bottom back… will have to try it and see… when it arrives!
You may have to do something there ours was completely square?
As I said, the 2 words "per hour" only add confusion.
The unit of electricity is not amps per hour. It is (the French and original ) Ampere Hour. Or in English Amp Hour.
