- Jul 19, 2022
- 188
- 131
- 2015 HymerExsis i414
- 20+ years in 1990 VW T3 and Florida. Hymer now...
I know it's from China, and yes, it probably won't be as robust as a more reputable make. However, the idea of setting charge start and stop voltages is exactly what I need to do (to get around the Renogy self activation saga). I've got one on order and hope to set it up using a small bench PSU (which I used to top balance my LiFePO4 cells). I'd never thought of temps affecting it.I don't think I would trust the AliExpress item, and in any case it doesn't seem to include any BT connectivity, so has less adjustability than the Ablemail unit.
However, it does seem like a more sophisticated version of the BatteryMaster type devices in that it actually uses a relay to turn charging on or off according to the voltage thresholds you set, though how stable these are with temperature changes is open to question.
Still, as far as I know the BatteryMaster type gadgets are entirely passive devices which just use the voltage drop across a diode to control charging, which is a very crude way to do it!
I'm expecting the relay to be NO, so if it fails it won't constantly charge the starter battery. But that doesn't stop sone other aspect causing it to fail closed!
Where in the East Midlands are you? I'm in Chesterfield. If this fails I might ask to borrow your BT module for some beer tokens!
