T
Tackle man
Can anyone tell me if wheel covers help preserve the alloys?
I know they help protect tyres.
Doubt it, and any damp trapped would make the corrosion worse. But I suppose it would prevent uv degrading the varnish - so perhaps it might! But why get alloys only to cover them up?Can anyone tell me if wheel covers help preserve the alloys?
I have a genuine question..... other than vanity what is the actual point of alloy wheels?
Given the weight of a typical MH tyre I suspect the percentage saving of a complete alloy wheel with tyre fitted over steel is marginal. And I suspect a ventilated disc is probably heavier than a solid one or at least of similar weight. They are not fitted for weight saving.The whole point of Magnesium alloy wheels is to reduce the unsprung weight.
Anything on the road end of the springs or suspension is unsprung weight and it is this that reduces road holding.
So ventilated discs low weight alloy parts including wheels lowers the unsprung weight and increases road holding.
I can't imagine how one would tell in 3.5 / 5tonne vehicle but you sure as hell can in a half tonne track car.
Is it not the case that those with alloys think they look great, those with steel wheels look at the cost of upgrading to alloys and then decide that the steels look better.
And while I am in moaning mode why do people with VW vans put low profile tyres on skinny spoked alloys on them? Don't they realise it's just a van?
So I'm with Choc's!
Gosh, you're easily wound up! I wasn't referring to solid disks with holes in them but the sort of ventilated discs fitted to typical cars which I suspect are heavier or virtually the same as an equivalent solid one, assuming both were made out of the same material. And of course reducing unsprung weight is a good thing but the point was for a MH why bother? Unless you are looking for a technical excuse to justify the expense!I didn't say it wasn't marginal but any reduction reduces unsprung weight.
You suspect ventilated discs are heavier says that you DON'T know that they are heavier, because they are in fact lighter for the reasons I attempted to explain.
Broken Link Removed
This is a lightweight disc and it has not been produced for it's surface area breaking efficiency it has been done to reduce the unsprung weight.
You like many others might fit alloys to satisfy your vanity but please do not attempt to convince me that I'm wrong when I'm not.
Much to my humiliation try telling that to my 30 y/o T5 owning son! He spent the equivalent of an arm and two legs for a set of black alloys with fat tyres....... good job he's in the medical profession
But hey, that's modern yoof
Me? steel wheels all the way. Low tech, cheap and easy to maintain. They have a job to do and they do it well
you could buy a set of after market flares for a 4x4 and cut & join them to fit. saw a van with a set of them fitted before and although obvious, looked alrightive fitted these alloys on my fiat ducato very please with them, only problem i have is they stick out more than my arches, had an adisory on MOT so im on the look out for some wheel arches any ideas ?
regards
we had steel on our previous home, always looked a bit tired and not that easy to clean, alloys came with alloys and look great - so far. Agree that it might not enhance the handling but they do add to the overall look of our tip top motorhome.Originally, around the 50s ( earlier ? ) they became common in racing cars because they were lighter, which is good. BUT the emphasis is on racing, they were light and they were only just strong enough to last on smooth tarmac. Some idiots used them on the road and they collapsed. So road alloys were made that ended up as heavy as steel to take the knocks of the road.
It's a bit laughable to consider trying to enhance the handling of a MH by fitting allows.
