1200
Nearly enough!
1200
Not wishing to argue but those couple of small wheels are going to have to support the best part of 1000kg EACH to keep the cross member clear of the floor.
Unless the wheels are machined from steel bar with substantial mountings on the chassis ends they simply won't carry that weight.
Then of course, you just lost maybe 3 or 4 inches of normal ground clearance for the mounts and wheels so will ground at times you normally wouldn't.
You’ve got it in one.
The last thing you want to do is fit wheels, or anything else that sits lower than the existing chassis.
All that achieves is to increase the frequency of grounding and increasing the magnitude of forces transmitted to the chassis/bodywork.
Ian
Ouch!After nearly 9 months, and two attempts at getting the right part delivered, it was finally fitted in December. Wallet is £1400 thinner...maybe I should have asked for it to be teflon-coated (the chassis, not the wallet!) ;-)
