- Dec 31, 2010
- 2,984
- 7,083
- Frankia Platin i7900
- Since 2010
You need to have the heat exchanger fitted
You need the heat exchanger which will use heat from the engine cooling system to warm up the heating fluid. They can be an add on extra or included in the package. Ours was included as part of the package that was specced by the dealer. If you are planning any skiing or arctic trips it also works in reverse, allowing the engine to be preheated by the motorhome heating system to help it start easier in really cold weather.How would I get my Alde system to warm on the move?
It is a small heat exchanger that will be out of sight somewhere; ours is under the driver's seat. If you tell us what motorhome you are considering someone with one may be able to tell you where it is. There will also be a switch somewhere visible to switch on the auxiliary pump needed for the engine prewarm function, In our Hymer it is over the entrance door next to the control panel.Any idea where it would be fitted and what it looks like, hoping I already have it.
It could well be hidden in lockers or under the seat. They are rarely on display. But they are an extra to the "basic" Alde system so may not have been included with yours. Ours was part of the Hymer Alde Arktis package.I have a 2012 Bessacarr e562, don’t recall seeing anything like that.
Alde sell a heat exchanger that connects on one side to the cab heater connections and on the other to the Alde radiator circuit. Like this:How would I get my Alde system to warm on the move?
Could be down to poor installation
did you tee into the existing hot distribution pipe work or does the deiesel one just fire direct into the van?I have an older Truma Combi-boiler with a thirsty 12V fan requirement in My Dethleff's Motorhome and have now fitted an 8KW chinese diesel air heater as it runs on diesel with a long lasting 12V fan.
Diesel can be bought any where so saves on gas when wild camping.
As a Flintshire Mobile Motorhome and Caravan Technician I can recommend the diesel heaters.
Alde have anti-freeze so less chance of freezing.
Truma usually have frost control dump valves but you will lose your water when they dump.
Alde are usually a more expensive system.
All systems have there Pro's and Con's.
We have 4 in the lounge area and up the back of the sofa, also along the front of the dash between blind & screen. 1 in the shower, 1 in the toilet, 1 between toilet & shower. Vents along the sides of both beds that can be turned off. All pipework in double floor also outlets into tank enclosures and toilet cassette housing. And 1 in the garage.I think your right. We have just one outlet into the hab area and one in the bathroom at the rear of the van and the they ran the pipework externally under the van which I have lagged it with armaflex along the whole of it's route, which improved it greatly, but I'm thinking of fitting a tee in and piping to an outlet further towards the front of the van.
Welcome Yorkshirelad175 from us in S Yorks! We’re on our first van 17months and had Alde heating, once you get used to the operation of the system and control panel it’s great!Thanks guys and galls, seems like Alde has the vote. I really appreciate all your input.
All I have to do now is pluck up the courage to “part wi some brass” and buy a motorhome. Being a Yorkshire lad parting wi brass don’t come easy ! ?
